Old 06-27-2015, 02:07 PM   #1
cplcorndog
69 c10 with 68 front end
Hello all I'm Joseph and here is a little bit of what I have going on. 383 .40 over with cam specs 274/286 duration, 519/523 lift, 106 degree CL, 110 degree lobe separation, 350 trans, unsure of rear end, 670 Holley avenger, custom aluminum tig valve covers, cfr complete pulley front end, cpp tilt column with cpp 500 power steering box, cpp bed mount tank. I'm also in the process of installing an NRG short hub with quick release and NRG steering wheel just having problems with getting the horn to work.
Anything you you guys want to suggest, comment on, or correct me on please do so. I'm a big boy and I'm looking for information of all kinds because this is my very first build.
Thank you so much for looking, and I hope to hear from you guys.
cplcorndog is offline   Reply With Quote
