Old 06-28-2015, 03:04 AM   #1
noguirre71
noguirre71's Avatar
Lower control arm help
Hey guys in the process of rebuilding/replacing the front suspension on my 71. I decided to change the u bolts and while I had the lower control arm off I though "hey why not the control arm shafts" well when I went to loosen up the left side it was loose, sloppy and had a lot of play. I was able to take it off by hand. Well today I take a closer look and see that it's cracked. My question to you guys...is this lower contral arm fixable??? Should i put the money to fix towards a new control arm instead?? What are your thoughts guys?? Thanks in advance for all the help!
noguirre71 is offline   Reply With Quote
Old 06-28-2015, 03:05 AM   #2
noguirre71
noguirre71's Avatar
Re: Lower control arm help
Another pic
Old 06-28-2015, 03:08 AM   #3
noguirre71
noguirre71's Avatar
Fixable? Should I worry about this? Or hurry and buy a replacement? You can't really see the crack in this one but it's on the lower side of the picture.
Old 06-28-2015, 03:23 AM   #4
noguirre71
noguirre71's Avatar
Found my answer guys. Thanks
