If I needed a truck to build a wrecker on this would be it ....
http://www.ebay.com/itm/171834509724...S1.M743.R1.TR2
I wonder if you only wanted the cab for a pickup ,just what would you give for a perfect cab ?? |
Re: If I needed a truck to build a wrecker on this would be it ....
Nice
![]() I would just get the pump working again and use it for a fire truck. Would be handy around our place, and with the short wheelbase and weight on the back it would go just about anywhere you needed to go even without 4wd.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
Post Whore
![]() Join Date: Mar 2013
I agree, that's a nice truck to leave as is. Another member just posted it not to long ago I believe.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#4 | |
![]() Join Date: Aug 2010
![]() ![]() Join Date: Apr 2012
The seller states "The cab is the same as a standard pickup" well that's not entirely true . The floor is lower on these larger trucks and the firewall has a welded brace around the firewall opening to the trans tunnel. Nice looking floor matt but that wont do you any good either , column , wiring harness complete front end except hood are all different. Its not a bolt on deal without some cutting and welding. Then you have the big hole in the roof to deal with !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
It would be a damn shame to cut up a nice old medium duty like that
It's cool but it's days as a piece of fire equipment are over. If I had it I would turn it into a motorcycle carrier. In it I would carry a 39 knucklehead and a triumph bonneville. But then again if I had that much money I would just quit work!
#8 | |
![]() I don't have the money for it right now, but I was actually getting interested in it as a private fire truck until I read that the apparatus was no longer functional. I've been thinking about retiring from the local VFD and just staying home and protecting my own property.
