Old 06-28-2015, 02:58 PM   #1
chevak20
Suburban Door Solution
I have to share a door alignment solution. On my Suburban rear passenger doors, the doors would not close all the way. The door pin was not worn out, so that was not the cause. I took the lock off the door and noticed that the latch did not close all the way around the pin. So I welded a little bit on the lock, after removing it, so the lock would fit snugly. After figuring out where to weld, I did not have to take the lock off the second door. It went faster on that door.
chevak20 is offline   Reply With Quote
