06-28-2015, 09:11 PM | #1 |
Anyone running a Boyd Welding tank please come on in
I installed a Boyd welding tank in my 1966 C20. I need to know what to use to plug the fuel tank drain plug. The thread size is 3/8" NPT. Boyd's does not show a drain plug on there website. I emailed them and they said they don't sell one.
I went to Lowe's and bought a 3/8" NPT brass plug. I put permatex thread sealant that said is safe for gasoline on the threads but it's still leaking. So what did you use? Thanks, Matt
It only has original paint once |
06-29-2015, 06:49 AM | #2 |
Re: Anyone running a Boyd Welding tank please come on in
I have my pickup in that hole. I used permatex pipe sealant with teflon. Been fine for a couple of years so far.http://www.permatex.com/products-2/p...th-ptfe-detail
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
06-29-2015, 09:31 AM | #3 |
That's where I run my fuel return to. But the right thread with the right sealant shouldn't leak. Try a different sealant type.
06-29-2015, 10:23 AM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
I run my feed from that location.( Passenger side low on the tank) My return is on top of the tank.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-29-2015, 11:59 AM | #5 |
My tank has the in-tank EFI fuel pump, hence why I feed from the top. I put my return on the bottom so I don't have any pouring effect as the fuel returns. The top return was too close to the pickup for my liking and I didn't want any kind of aeration effect of making the fuel splash around the pickup.
06-29-2015, 08:09 PM | #6 |
Thanks everyone for the replies I just went and bought Permatex thread sealant with teflon.
07-01-2015, 02:39 PM | #7 |
That should fix it...I have that same brass plug, a few wraps of tape and haven't had a leak even one time.
T
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
