06-28-2015, 10:32 PM | #1 |
grille support
what if any differences are there between a 62 and a 64 grille support besides the mounting holes for the grille.can i use the 62 support with a 64 grill if i drill two new mounting holes?
06-28-2015, 10:40 PM | #2 |
Re: grille support
The 1962 has a wider frame than 1963 and up. Thus, the notches at the bottom of the grille support will not be in the correct place. Here's my 1965 grille support so you know what notches I'm referring to.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
06-28-2015, 10:47 PM | #3 |
Re: grille support
you mean the notches for the frame? the po put a 62 support and grille on and it looks like he modified those notches. i have an origional 64 grille but i cant afford a grille support right now,so i guess my question is can i make it work without it looking funky?
06-28-2015, 10:50 PM | #4 |
Re: grille support
Yes, the frame notches will be different. If you move the notches or just widen them then you should be OK. Bumper should hide most of the carnage.
06-28-2015, 11:00 PM | #5 |
Re: grille support
thats a smooth looking front end! thanks for the pic,guess i'll start looking for a 64 grille support.
06-28-2015, 11:01 PM | #6 |
Re: grille support
lol thanks again
06-28-2015, 11:06 PM | #7 | |
Re: grille support
When I first read your post I thought you were gonna buy a 62 grille support and try to fit it on a 64 frame.
06-28-2015, 11:08 PM | #8 |
Re: grille support
TC, I have one you can have, just pay shipping.
06-28-2015, 11:26 PM | #9 |
Re: grille support
that would be great! here's a pic of where i'm at on my 64.my zip is 95321 can you find out how much and we'll work it out.do you have a pic?
06-28-2015, 11:58 PM | #10 |
Re: grille support
Your close, I can't believe it would be more than 40 bucks.
06-29-2015, 12:53 AM | #11 |
Re: grille support
I have a 62 support and grill on my 66 frame and the notches are in the right spot...
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
06-29-2015, 01:21 AM | #12 |
Re: grille support
I can definitely do that pm me the details and i'll send the check or whatever you want.thank you very much! I will pay it forward with the 62 i have now.
06-29-2015, 01:26 AM | #13 |
Re: grille support
Hey argo my problem was putting a 64 grill 0n a 62 support i know the mounting holes are different,so getting ahold of a 64 support solves the problem,thanks for the help!
06-29-2015, 04:37 PM | #14 |
Re: grille support
The distance between the frame rails should be the same in the front. It is not until you get under the cab do they start to flair out. You should be fine with that grill support unless you are worried about the width of the rails themselves. That I do not know about. One difference you might run into is if you are trying to use a 1 ton or bigger truck's grille support I think the hole goes higher up than on the half ton. You can see the holes on a 1 ton and not on a half ton the bumper covers them up.
06-29-2015, 04:53 PM | #15 |
Re: grille support
here's some pic's these are the grille support and grille i took off the truck,the holes in the support do not line up with the 64 grill i'm putting on.
06-29-2015, 05:07 PM | #16 | |
Re: grille support
Sorry for the confusion.
06-29-2015, 05:07 PM | #17 |
Re: grille support
oooops
06-29-2015, 08:39 PM | #18 |
Re: grille support
It will be a few days before I can get you a shipping quote, busy busy.
06-29-2015, 08:43 PM | #19 |
Re: grille support
no problem Lt1 just let me know,thanks
06-30-2015, 09:11 AM | #20 |
Re: grille support
http://67-72chevytrucks.com/vboard/s...d.php?t=612875
good thread that talked about the differences in the grill supports. I installed a 61 support on my 63 with no issues. Did have to drill the 2 extra holes to except the 63 grill. This is also one of the supports that had 6 factory holes drilled in it. The support was off a 61 st. Louis apache 10 (picture attached).
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-30-2015 at 09:17 AM. |
07-02-2015, 01:53 AM | #21 |
Re: grille support
that is sweet love the master cylinder color match.what brand radiator is that? is your grille a 64 ? the + patern looks thicker than mine,partial pic of mine in previous post.
07-02-2015, 08:24 AM | #22 |
Re: grille support
Thanks, the radiator is a Champion. The grill is a one year only 63 option in aluminum. They came in steel also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-02-2015, 09:13 AM | #23 |
Re: grille support
I want that 63 aluminum grill badly!!!!
07-02-2015, 09:32 AM | #24 |
Re: grille support
Took me a few years to find this one. Have managed to piece one together for the fleetside also. I removed the anodization which had faded badly and polished it out.
07-03-2015, 01:58 AM | #25 |
Re: grille support
that grille is the bomb! i knew there was something special about it,any luck on the shipping price LT1?
