Old 06-30-2015, 09:40 AM   #1
bmur66
Removing front clip on my "65
My project truck has been sitting still for about a year now. I bought it as an incomplete build. A couple things derailed my progress. What I found was a broken engine block on one of the starter mounting holes. I mounted a mini starter and it seems to start fine but in the long term I am considering the big block 396 to be junk (after I wasted $ on a nice carb, coated headers, chrome, wires, etc...). It runs good but I will most likely replace it with a small block crate motor or 5.3. Also the top of the frame rails were trimmed to fit big block headers. I am not thrilled with this and want it repaired. Additionally I want to convert to front power disc brakes and replace all of the brake lines with a quality done job.
With all things considered I have decided I need to remove the front clip (doghouse?) motor and tranny so I have access to do things right and the way they should have been done in the first place.
So, I have never removed the front clip on a vehicle before. I will fabricate something in my garage so I can store the hood and front clip safely without hurting the nice paint but I have no clue how to best remove it. Can someone give me some good direction here? I'd sure appreciate it. Thanks
No Weak Links
bmur66 is offline   Reply With Quote
Old 06-30-2015, 09:41 AM   #2
bmur66
Re: Removing front clip on my "65
Sorry about the pic. My truck is not hanging by its rear bumper as it appears
No Weak Links
Old 06-30-2015, 10:02 AM   #3
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
So what Exactly is wrong with the 396? Just a tired engine that you never rebuilt?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-30-2015, 10:07 AM   #4
bmur66
The block is broken. A chunk is missing where the starter mounts. Only using 2 of the 3 bolts (studs)
No Weak Links
Old 06-30-2015, 10:21 AM   #5
doobiebro
doobiebro's Avatar
Here you go with a nice illustration...http://67-72chevytrucks.com/vboard/s...t+clip+removal
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 06-30-2015, 10:54 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
On this pic: http://67-72chevytrucks.com/vboard/s...97&postcount=4
He's talking about the (front fenders) lower rear fastener on each side that's not shown.
Old 06-30-2015, 11:22 AM   #7
bmur66
Wow. Ask and ye shall receive. You guys are awesome!
No Weak Links
