Old 06-30-2015, 12:14 PM   #1
c10_head68
c10_head68's Avatar
Question 1968 c10 How low can you drop a 6 lug, with brake drum all the way around
Hi I've want know how low you can go on a stock1968 c10 6 lug with brake drums on all 4 sides? If anyone has pictures or a truck dropped or link to another post ? thanks
c10_head68 is offline   Reply With Quote
Old 06-30-2015, 12:17 PM   #2
c10_head68
c10_head68's Avatar
Re: 1968 c10 How low can you drop a 6 lug, with brake drum all the way around
This is the truck!
Old 07-01-2015, 12:52 AM   #3
sy2767
sy2767's Avatar
Pics of my truck here and I think its been dropped 4" in the front and 3" in the rear, stock drums and 6 lugs still there. Its a brute to stop straight and smooth. lol
sy2767 is offline   Reply With Quote
Old 07-01-2015, 01:14 AM   #4
c10_head68
c10_head68's Avatar
Question Re: 1968 c10 How low can you drop a 6 lug, with brake drum all the way around
Looks sick! How did you drop it in the front?
Old 07-01-2015, 01:22 AM   #5
sy2767
sy2767's Avatar
I didn't, i purchased it like this. Just shorter springs in the rear and drop spindles and springs in the front.
Old 07-01-2015, 01:27 AM   #6
c10_head68
c10_head68's Avatar
Is it disk brakes in the front or drums? I've been looking for drop spindles for drum brakes and I can't find them anywhere
Old 07-01-2015, 01:44 AM   #7
sy2767
sy2767's Avatar
Still drums up front, not sure what spindles were used sorry
Old 07-01-2015, 11:54 AM   #8
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Everyone needs to see pics of these spindles as thee has never been ANY dropped spindles for drum brakes, that anyone has ever seen or heard about.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-01-2015, 12:26 PM   #9
sy2767
sy2767's Avatar
Wow I was not aware of that, I am only going by what I was told by the previous owner. I will snap a few pics and post them up, maybe he just thought or assumed they were drop spindles . Now you have me asking is a 4" drop even possible with just springs?
Old 07-01-2015, 03:52 PM   #10
SCOTI
SCOTI's Avatar
chevy_mike is correct. There are no aftermarket drop spindles for drum brake set-ups. 4" front drop can be achieved w/very short springs, springs & modified a-arms, or springs & a modified x-member.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 07-01-2015, 06:41 PM   #11
chevy_mike
chevy_mike's Avatar
Since the pics of the truck seem that is is somewhat level, I would almost think the drop is a 3" front (springs) and 4" rear (springs). This would make sense and seem more likely. Since the rear typically sit 2" higher than the front, a 4" front, 3" rear would make the truck have a much bigger rake than what it shows.
Just my .02 worth. Cool looking truck either way!!!
Old 07-02-2015, 11:30 AM   #12
c10_head68
c10_head68's Avatar
What would be an easy way to lower ? A just pulling off front suspension of a 80s c10?
Old 07-02-2015, 12:11 PM   #13
chevy_mike
chevy_mike's Avatar
If you are pulling the front suspension off an '80's truck, does that mean you are switching to disc brakes? Your first post says you are all drum. If drum, lowering springs and/or dropped lower A arms are your options. If disc in front, then dropped spindles and/or springs would be best. You can always go with air bags too and have an adjustable height.
Old 07-02-2015, 12:30 PM   #14
c10_head68
c10_head68's Avatar
Air bags would be my main goal for my truck, would it be easier to bag with suspension of 80s c10? I am drum brakes all the way around, I wanted to lower it and keep it 6 lug with drums ,but now I realize it would never be as low as I would want it to be with drums
Old 07-02-2015, 01:37 PM   #15
SCOTI
SCOTI's Avatar
Why no disc brakes?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-02-2015, 02:00 PM   #16
c10_head68
c10_head68's Avatar
Wanted to keep it mostly stock, but disks are most likely what is going on it ,since I can Pull them off later model c10s
Old 07-02-2015, 02:58 PM   #17
SCOTI
SCOTI's Avatar
Mostly stock means don't lower it then .
Stock drum brakes are ok @ best compared to the later model discs that are easily swapable. Doing the swap & utilizing drop spindles sure seems easier & more cost effective vs dropped control arms or other alternatives.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-02-2015, 04:48 PM   #18
c10_head68
c10_head68's Avatar
Yeah that's true ,wouldn't be stock then haha,
Do you know if I would be able to just swap the out the spindles and brake parts of an 80s c10, and install them on the old control arms on my truck?
Old 07-02-2015, 05:06 PM   #19
SCOTI
SCOTI's Avatar
Yes. You'll want the 'conversion' spindles as they utilize your existing drum brake steering components.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-02-2015, 05:30 PM   #20
c10_head68
c10_head68's Avatar
Talking Re: 1968 c10 How low can you drop a 6 lug, with brake drum all the way around
Thanks a lot for the link it really cleared a lot of my questions up !
Old 07-03-2015, 06:06 AM   #21
dirtyjim
dirtyjim's Avatar
you can always do stepped control arms. there was a truck on here a while back that did have a set of drum brake drop spindles, they were on the truck when the guy bought it and looked very old. they were most likely fabricated. I have pics somewhere
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 07-03-2015, 02:51 PM   #22
c10_head68
c10_head68's Avatar
Pictures would be great man!Thanks
