Old 06-30-2015, 01:08 PM   #1
MikeCofield
Rear disc brake brackets
I have 2 sets of rear disc brake bracket . These use the impala rotor and camaro caliper . Bought these from a board member $90 per set shipped
MikeCofield is offline   Reply With Quote
Old 06-30-2015, 08:01 PM   #2
empi1776
Re: Rear disc brake brackets
Hi
what caliper and rotor does this use, and can you use emergency brake on calipers.
THank you
empi1776 is offline   Reply With Quote
Old 06-30-2015, 09:08 PM   #3
jmedero
jmedero's Avatar
Yes the 93-97 Camaro rear calipers. Not sure if the 98-02 work but I've used this set up with 97 z28 calipers with e brake and it worked great.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-08-2015, 09:43 PM   #4
MikeCofield
$80 set shipped
Old 07-08-2015, 09:55 PM   #5
RUN GMC
RUN GMC's Avatar
Will these work on a 87 GMC rearend? Will the Wilwood D52 bolt up to these?
RUN GMC is offline   Reply With Quote
Old 07-08-2015, 09:58 PM   #6
MikeCofield
They were designed for the 71-2 12 bolt truck rearend and use the 95 impala rotor and 93-97 camaro caliper
Old 07-14-2015, 10:35 PM   #7
MikeCofield
2 sets available
Old 08-01-2015, 02:08 AM   #8
MikeCofield
2sets available
Old 08-01-2015, 01:35 PM   #9
Jsleeman
I am interested in a set.
Jsleeman is offline   Reply With Quote
Old 08-03-2015, 07:46 PM   #10
halfstep
I will take a set @ advertised $80 shipped.
PM me on how to proceed. I can do PayPal, etc.
Thanks!
halfstep is offline   Reply With Quote
