![]() Join Date: May 2014
Painting plastic inner door panels
I need black panels for the doors of my 72 K-10, and my originals are in nice shape, except that they are green (Parchment?)
Is it possible to paint these panels, and have them hold up? I was planning on using a matte finish black spray that says it's for plastic, but I hate to ruin a perfectly good pair of panels if it won't work. I've been searching for some good black panels, but so far, no luck Attachment 1420965 Attachment 1420966
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
![]() Join Date: Dec 2013
Re: Painting plastic inner door panels
Yes . You can recolor your door panels and have it any color you want use plastic adhesion promoter called Bulldog . after serious dawn dish detergent cleaning and using a wax and grease remover you spray the panels lightly with BULLDOG and the use any sem or plasticoat plastic color dye you want available at most auto parts stores .
SWB 4x4 Collector
![]() Join Date: Jun 2001
Bulldog adhesion promoter and either krylon "fusion" satin black or sem landau black.
*Clean panels with dish soap and a tire brush or toothbrush to get all the grain clean * spray mist coats of adhesion promoter (after panels are dry) with 10-15 minute intervals *spray plastic dye (sem brand or krylon) in mist coats approximately 15-25 min after last adhesion promoter coat. (Key here is mist coats, dusting of color. Don't do one heavy coat. The less coats the better for adhesion and better results. By the way, your panels are medium green, parchment is a off white color. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Cleaning is a very very important first step to assure you get all remnants of armoralland any other silicone based shine it up stuff off to have a shot at a good job
SEM paint bonds to plastic great when prepared properly. Have you considered maybe trading a board member? Maybe someone here is looking to swap panels.
Moderator
![]() Join Date: May 2007
If you are using black, I have had excellent results with Mar-Hyde brand spray. I've used it on vinyl seats as well and it does not come off.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
the hardest part will be to remove any silicoln amour all type products that may have been put on them in thier life. I have never successfully removed it totally befor painting and sux when that happens. becarefull what claening products you use cause some may disolve the plastic door panel
Thanks for all of the tips. I cleaned them up, first scrubbing with Purple Power, then a strong concentration of Dawn and water then some wax and grease remover. I haven't picked up the paint yet, but will be sure to clean them again before painting
![]() Join Date: Apr 2005
SEM paint works really well.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I wish I had black ones to trade you. Those are really nice and the color I need for project "Amatouring"
PPG has a system for plastic prep that is the best I have used. If you look at their One Choice system they have plastic prep that has a cleaner/scuff as step 1 then a adhesion wipe as step 2 followed by adhesion spray. This system will cost about $30 and will make other products stick like factory paint.
![]() Join Date: May 2013
Ive had good results useing simple green to clean , bulldog as an adhesion promoter , and sem vinyl dye as the top coat , use a very light application of bulldog , it goes a long way
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#13 |
I have had very good long lasting(7+years) results from VHT I believe Dupicolor bought out the dye division from VHT Prep is key.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
