Old 06-30-2015, 11:53 PM   #1
UKNOWME
UKNOWME's Avatar
Detent cable bracket
Is the bracket the same for TH350 and 700R4? I'm using an Edelbrock carb also.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 07-01-2015, 09:02 AM   #2
77c10
77c10's Avatar
Re: Detent cable bracket
I may be wrong but I believe they are different.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 07-01-2015, 11:45 AM   #3
greg64
greg64's Avatar
I don't see how they could be the same. The th350 just has a kick down cable that gets a tug when the throttle hits wide open. The 700r4 uses a TV cable that modulates with throttle position (constant motion).
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 07-01-2015, 11:50 AM   #4
gmachinz
You also need to carefully adjust the TV cable on the OD transmissions to prevent early valve body failure. There's a clip that you pull up on and seat the cable in fully-once mounted, connect to carb, then slowly open throttle up fully, once you have the throttle fully open, snap the clip back down-your TV is now adjusted. You need to use the correct bracket too though-Edelbrock has a dedicated TV cable bracket for use with their carbs-don't try to use a stock OD bracket from a Q-Jet engine....just order the correct bracket from Edelbrock-Summit/Jegs whatever.
gmachinz is offline   Reply With Quote
Old 07-01-2015, 03:00 PM   #5
UKNOWME
UKNOWME's Avatar
Thanks all for the info and thank you gmachinz for the detailed info!
1964 Chevy c10
Old 07-01-2015, 09:51 PM   #6
gmachinz
No problem. I recently put a TCI 700R4 in an older truck and that's how I set it up. OD came in right at 40MPH. It uses a vacuum controlled lockup switch which required @ least 15 inches of vacuum for 20 seconds or longer to engage-once engaged, OD stayed in placed unless manifold vacuum dropped below 15 inches in which case tranny shifted down to 3rd gear. Combine that with factory cruise and it was a nice drive on the freeway-OD would engage and disengage without any problems with cruise set-so just make sure you set the TV cable and you shouldn't have any problems.
Old 07-01-2015, 10:45 PM   #7
UKNOWME
UKNOWME's Avatar
I may be stupid but I don't think mine is vacuum controlled.
1964 Chevy c10
Old 07-01-2015, 11:05 PM   #8
GRADYS Performance
GRADYS Performance's Avatar
He is talking about the vacuum switch TCI uses for the Converter lockup wiring harness. It helps control converter lockup based on engine vacuum.
TCI has a Throttle cable/TV cable bracket to fit your carb. PM me if you have any questions about it.
GRADYS Performance is offline   Reply With Quote
Old 07-01-2015, 11:28 PM   #9
UKNOWME
UKNOWME's Avatar
Where's the vacuum switch? Have any reference pictures?
1964 Chevy c10
Old 07-02-2015, 12:05 AM   #10
gmachinz
If your truck has a factory OD, no need for the adjustable switch....just buy the correct bracket for your carb:
Edelbrock/Carter AFB carb takes a B&M #64511
Holley carb takes a B&M #64510
Now, if your truck did not have OD originally, you also need a lockup kit-I'd recommend this one:
http://www.tciauto.com/tc/2004r-700r...iring-kithtml/
Besides my harnesses I am also a full service performance parts retailer as well-let me know if there's anything you need or have questions about!
Old 07-02-2015, 12:53 AM   #11
UKNOWME
UKNOWME's Avatar
Mine is an 80 so it did not have OD. What happens without it? I've been driving it without the cable hooked up so far. Once I correct that what happens if the lockup is not installed?
1964 Chevy c10
Old 07-02-2015, 01:11 AM   #12
gmachinz
If the TV cable isn't adjusted properly the pressure inside the valvebody can create excess heat and eventually it can fail to shift properly then not at all. Sometimes it can take awhile but a poorly (or not at all) connected TV cable is going to ruin your transmission.
Old 07-02-2015, 08:37 AM   #13
UKNOWME
UKNOWME's Avatar
Ok, thank you
1964 Chevy c10
Old 07-02-2015, 05:46 PM   #14
GRADYS Performance
Do you know if GM made a throttle cable/TV cable bracket to fit a Qjet that bolts down with the rear carb bolts for the th700?
