Hood Prop for a 41-46
What are you using to hold the hood open on your trucks???
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
![]() ![]() Join Date: Nov 2008
Re: Hood Prop for a 41-46
You're in the wrong sub-forum.
That said, when I had my '46 I DID'NT "prop" it. It laid back on itself and as long as I was gentle with it there was no paint damage, etc.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
I used a broom handle, but that was 45 years ago....
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Early dodge had some hood props that mount on the round bar supports that run from firewall to grill shroud. They close flat when not in use.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
This is what i used. They do repop these. I paid about $100 couple years ago.
http://www.ebay.com/itm/DODGE-TRUCK-...757a9b&vxp=mtr
looks easy enough to build for about $10
add $0.25 for a nos rubber tip ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
ufda... big pic
Thanks folks for the input, I did look at some hood props for a 30's Ford that bolted to the rad to cowl support rods
