Old 07-01-2015, 10:17 PM   #1
jame
1963 Vent window pivot rivet
One of my frames has the upper pivot missing altogether. Cant seem to find this rivet for sale by itself or in a kit. It is different than the 64-66 style. THanks
1963 chevy shortstep 327
1965 c60 292
2007 Ram 3500 5.9 cummins
jame is offline   Reply With Quote
Old 07-01-2015, 10:44 PM   #2
pimpston65
pimpston65's Avatar
Re: 1963 Vent window pivot rivet
evilbay is a good source, just gotta think outside the box, use measurements instead of application...
pimpston65 is offline   Reply With Quote
Old 07-02-2015, 08:37 AM   #3
1963c-10
1963c-10's Avatar
Yeah, you will have to source a used vent assembly. The pivot is not available separate that I'm aware of.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-02-2015, 06:01 PM   #4
nsb29
nsb29's Avatar
try your local bolt an nut if they don't have it they can probably order it you would have to order a minimum amount we have a place hear called Fastenal I think they are national
nsb29 is offline   Reply With Quote
Old 07-02-2015, 09:03 PM   #5
jame
I'll keep the frames for the future. I'm going to look into the one piece conversion from Classic Truck Glass since I need to replace everything else anyway. Thanks
1965 c60 292
