Old 07-02-2015, 10:02 AM   #1
rs74
rs74's Avatar
Thinking about a 5.3 in my 93. Any links?
Just thinking about making my 93 a good dependable daily driver with a little extra umph. I thought about putting it in my 85 short bed that I am doing but I like the ride of the 93 and think it would make a fun truck to drive as well. Currently looking at a 00 Z71 with 116,000 miles on it that has been wrecked. Not sure on things like if the 00 truck accessories are fine for the 93 and if it is just pretty much a drop in except for engine mounts. I would probably be looking at just leaving it in stock form with the factory exhaust manifolds and a tune. Just looking for direction. Seems like most of these swaps on this page are for other year body styles. I flipped through about ten pages and really didn't see anything that stood out for this body style.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 07-02-2015, 11:30 AM   #2
OutlawDrifter
Re: Thinking about a 5.3 in my 93. Any links?
go check out ls1tech.com, lots of good info on that site.
you'll probably need a right hand high mount bracket for your ac compressor. should be able to use everything else. are you keeping your trans or using a newer 4L60E?
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 07-02-2015, 12:17 PM   #3
UP GRADE
one set closer
UP GRADE's Avatar
Here's one I've been looking at for a few months. Lots of info. LS1Truck.com
UP GRADE is offline   Reply With Quote
Old 07-02-2015, 01:29 PM   #4
rs74
rs74's Avatar
I would have the tail shaft on the newer trans changed to a 2wd or I have a newer 2wd trans that needs rebuilt if it will work. It is something like a 00-03 transmission.
Old 07-02-2015, 04:14 PM   #5
MalibuSSwagon
Yea I'd use the high mount bracket for an R4 compressor. A guy in my local club did a 5.3L swap in his b-body wagon, literally just unbolted compressor and set to the side without breaking the lines open, and then put it on the 5.3L once in the car and done, ice cold AC retained.
MalibuSSwagon is offline   Reply With Quote
Old 07-02-2015, 04:27 PM   #6
GMC-YA68
GMC-YA68's Avatar
street and strip performance has a whole write up / video somewhere.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 07-02-2015, 08:01 PM   #7
Mikec10
Mikec10's Avatar
check out lt1swap.com aswell (says lt1 but lots of 4.8,5.3,6.0, LS harness info)
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 07-02-2015, 10:36 PM   #8
rs74
rs74's Avatar
Thanks guys. I will check them out. Still up in the air on the 93 or the 85.
Old 07-07-2015, 11:05 PM   #9
brushbuggy
brushbuggy's Avatar
I did a 5.3 swap in a 90 pickup ,used the holley a/c brackets and stock manifolds runs way better than the old 350 and was able to make all the stock gauges work
brushbuggy is offline   Reply With Quote
