Old 07-02-2015, 01:01 PM   #1
Tool Maker
Where do the headlight grounds go?
Ok so I FINALLY got this truck on the road and almost got all the small stuff done but I have to put the grill and headlights back in. They were off when I bought the truck and the headlight buckets were unmounted from the grill. But for the life of me I can't find the original spot for the headlight grounds! Anybody have pics they can show me? Thanks!
Tool Maker is offline   Reply With Quote
Old 07-02-2015, 01:08 PM   #2
blown240
blown240's Avatar
Re: Where do the headlight grounds go?
I ended up having to run a wire to the battery ground bolt.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 07-02-2015, 01:36 PM   #3
1963c-10
1963c-10's Avatar
From the factory the screwed into the grill support. I run those grounds and a separate to the frame also....
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-02-2015, 03:05 PM   #4
Tool Maker
Awesome. I am going to run it into the body right behind the headlight that way I can take the grill off and not have to fool with wires.
Also, where can I get the gears to swap in the rear end? What model do I need? This thing sounds like it's gonna blow up at 60 mph with the 350 turbo trans. Excuse my termanology. I've owned imports for 10 years and I decided to grow up I guess lol.
Old 07-02-2015, 03:28 PM   #5
1963c-10
1963c-10's Avatar
Will depend on which rear end you have. What year truck? Any pics of the rear diff cover?
Old 07-02-2015, 03:36 PM   #6
Tool Maker
It's a 63. I'll try and get pics later.
Old 07-02-2015, 04:43 PM   #7
1963c-10
1963c-10's Avatar
If its still got the original rear diff, it will be a 12 bolt. If you look on the axle tubes you should see some stampings that will lead you to the original gear count. You can always pull the cover and look at the gears themselves as they are stamped also. (chart attached so you can decipher the rear code)
The 12 bolt gears are the same as are the seals, bearings...etc.
The only difference is the 63-early 64 using a 17 spline axle vs the later models using 30 spline.
Old 07-03-2015, 08:17 AM   #8
Lugnutz65
Lugnutz65's Avatar
Tool Maker,
I sent you a PM. I live in Irmo too.
Jay
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
