Old 07-02-2015, 09:09 PM   #1
Slow Build
Slow Build's Avatar
Can anyone identify these Trailing Arms?
I bought these trailing arms in a package deal. He thought everything was CPP but some of the other stuff wasn't. He said that he got them in 2005. Does anyone recognize what brand these are, or are they home fabbed? They look fairly HD but I'm wondering if they would articulate like they should.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 07-02-2015, 10:08 PM   #2
SCOTI
SCOTI's Avatar
Re: Can anyone identify these Trailing Arms?
Home/shop built.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-04-2015, 01:37 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Those look pretty stout - probably wouldn't articulate or flex much (if any), but that obviously depends on the gauge of the tubing used to make them. You could always use some swivel bushings up front. Hotchkis makes a swivel trailing arm bushing for C10 trailing arms - of course that depends on the size of the bushing eye in those trailing arms you have.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-21-2015, 04:52 PM   #4
Slow Build
Slow Build's Avatar
I guess the big question is if I can trust them. The eye side looks pretty good but I don't know about the axle mounting end. The welds look OK, but not great. I'm just don't know if butt welding on a training arm is safe. I will definitely have to do a little more research before any plans to install them.
The swivel bushings would probably be a good idea. I wonder if they would add any harshness to the ride since I'm guessing it's all metal instead of rubber or poly.
Past GM Trucks:
Old 07-22-2015, 10:13 AM   #5
SCOTI
SCOTI's Avatar
I'm OCD about being safe.... I would run those as long as some type of swivel joint is used up front.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-23-2015, 04:25 AM   #6
Slow Build
Slow Build's Avatar
I think I just found these arms at the classicparts.com.
The picture is small but they look like mine. I feel safer about using them now.
http://www.classicparts.com/1960-72-...tinfo/74-871/#
Past GM Trucks:
