Old 07-02-2015, 09:33 PM   #1
canadian_diesel1964
63 Control Arms to 73-87 Spindles, Finally!
Hey guys here's the part numbers you need....
Upper BJ k6186 moog #
Lower BJ 505-1021OS Raybestos (tacked in and lip hammered in a bit)
Outer Tie Rod Es409RT
Inner Tie Rod ES323L
Sleeve from POL OR ECE to match the rods.
This will work very good if you happen to have 73-87 spindles lying around or the ECE group has spindles that match the 63 ball joint tapers...
The Control Arm alignment hole goes to the front on my 63 here is the final result with 3" drop spindles and 1" drop springs ...also new larger LCA u bolts.
canadian_diesel1964 is offline   Reply With Quote
Old 07-02-2015, 10:07 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: 63 Control Arms to 73-87 Spindles, Finally!
Are 1963 control arms different than 1964-66? I always thought they were the same. Kudos to you for sharing the info and part numbers. I just wanna know if the same parts can be used for 1964-66 1/2T trucks.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-02-2015, 10:10 PM   #3
canadian_diesel1964
I am pretty sure that 63-66 are the same...easy way to confirm is if the original ball joint numbers match then they are the same...
Old 07-02-2015, 10:52 PM   #4
Mathew21
Mathew21's Avatar
Great information. Thanks for sharing.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 07-03-2015, 12:08 AM   #5
Captainfab
60-66 Nut
The '63-'70 C10 control arms are the same.
Old 07-03-2015, 07:12 AM   #6
canadian_diesel1964
Thanks Captain!
