07-03-2015, 04:34 PM | #1 |
Clutch Pedal Removal
Gents - I am going out to my shop tomorrow to remove my clutch pedal so I can weld some brackets for my hydraulic master cylinder conversion. Just wondering if there is any trick to it or any particular tool I'll need. Figured I would ask before I get there. Thanks and happy 4th!
Posted via Mobile Device |
07-03-2015, 06:24 PM | #2 |
Re: Clutch Pedal Removal
I dont know what it is your referring to but I guess its a 60+ C10... I think there all the same that I know of.. crawl under the dash you'll see.. its a cut and dried issue, easy to remove.. I did mine when I replaced the column. since the column was out the brake mounting bracket was off so it was real simple to remove,, One bolt, slide the shaft..
