HI ALL,
I have chevy 1967 c10 with porter built air suspension,am having a issues getting the front to level out. All i know is that it was the best set up for a c10. This is all the info i have PORTER BUILT STAGE 1FRT AIR BAG SUSPENSION W/KYB SHOCKS. PORTER BUILT STAGE 11 REAR AIRBAG SUSPENSION W/BUILT IN NOTCH KIT AND FULLY ADJUSTABLE TRAC BAR W/KYB SHOCKS. VIAIR CHROME 444C AIR COMPRESSOR. ITS the driver side that i can not get to level up with the of side. Hope the info helps.MANY THANKS RAMMER |
Re: Porterbuilt air suspension
take some pictures for us please.
67-72 parts collector,…
![]() Join Date: Nov 2002
It doesn't sound like a suspension issue.
It sounds like an air management issue. I agree, pictures of your air line routing and switch assembly would help.
Hi andrewmp6,lolife99
here are some pictures of suspension hope this help . Thanks for your help. Cheers rammer. |
Hi here are some more thanks cheers rammer
I can't tell which side is which for the front but one bag looks like it has less air in it then the other.The front do you have a valve pre wheel or one with it a t fitting to both of them?
Do you have air bag gauges that lets you know how much air is in each bags? I have (4) gauges, one for each bag, that tells me how much air, is in each bag. I have a 5th gauge, that lets me know how much air is in my air tank. also, the front bags should require more air in the bags than the rear air bags. I hope this helps. Clark.
Posted via Mobile Device |
Rammer-
It does look like the driver side bag is not inflated as much as the passenger side. Can you tell if each bag has the same amount of pressure? Can you tell if there is something binding? Do me a favor and send an email to tech@pbfab.com and I will see if I can help you get it sorted out! Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
![]() Join Date: Jun 2006
HI Andrewmp6,
Ihave 1 valve for the front and for the back,and i have 1 gauge in the cab which with 2 rocker switches 1 for the front and 1 for the back. CHEERS RAMMER HI CLARK I have no gauge for air tank and only 1 valve for front and 1 for back. CHEERS RAMMER HI NATE, I"LL GET A EMALL OF TO YOU,CHEERS TONY |
Square
if you only have one valve for two bags you leave nothing between the bags to prevent the air from traveling from side to side. so the heavier side of the truck is going to squat. it would be worth your time to add a valve for each bag.
Squarebody Syndicate |
Yeah the one valve between the two is the problem,Like said each wheel needs its own valve up and down.With it like that when you corner it will shift air from one side to the other making it handle worse.And if you do have a lose of air like a line blowing off or something you will have the front or rear slam on you vs if you had a valve pre wheel you only lose one wheel not two and could probably limp it home on 3 bags vs towing it.
#13 |
HI ALL,
Thanks for all your reply's with the help on my airbag troubles,its all way the same when you get a new trunk you alway hope things were done right?. Still it give me something else to add on to my ever grow list? CHEERS ALL RAMMER |
#14 |
How many ports do you have on your air tank?
#15 |
Hi Andrewmp6,
I had a look at air tank it seem to have 2 ports I've taken some pictures of air tank for you and the valve hope they help a bit . CHEERS RAMMER |
#16 |
Some more pictures
#17 |
More photos
#18 |
I'm trying to think what would be cheaper for you to add more valves to what you got or lose them for a valve block.
#19 |
If you can do the plumbing work yourself you could take the 2 ports you have t it and run 8 vales like you have now.And you would have to run new air lines to each wheel also.And you should add a set of air gauges if you don't have them.Avs makes a dual needle gauge so you can run 2 gauges for all 4 wheels.If you can't do the plumbing and wiring you could get a shop fix it or spend some more and valve block style which you can get from aiflift ridetech or even accuair.The airlift autopilot and ridetech both have build in gauges but your looking a grand for that kinda set up.
