Old 07-04-2015, 01:14 PM   #1
airbrushguy
1971 Brake booster
A friend gave me a booster for my '71 C10 with front discs. He says it was ordered for his truck that had the same options: 6cyl, manual front discs.
Do I need to add anything else since it was built for the same truck...just never installed?
airbrushguy is offline   Reply With Quote
Old 07-06-2015, 06:37 PM   #2
airbrushguy
Re: 1971 Brake booster
ttt
Old 07-06-2015, 07:30 PM   #3
leftybass209
leftybass209's Avatar
It should be a bolt and go affair. Consider the condition of the brake hardware though if you're adding boost. Rubber lines will quickly blow if they aren't in good condition. Also consider replacing the rubber line that links the front to the rear, above the rear axle.
leftybass209 is offline   Reply With Quote
