Old 07-05-2015, 12:59 PM   #1
crane.fletcher
Exclamation Fuel filler neck 71-72 Blazer/Jimmy
Needing a filler neck hose, & hardware from a 71 or 72 Blazer or Jimmy
crane.fletcher is offline   Reply With Quote
Old 07-05-2015, 03:24 PM   #2
1tuff71
1tuff71's Avatar
Re: Fuel filler neck 71-72 Blazer/Jimmy
Are you looking for the neck coming off the tank? If you are look for guys parting out one and see if they will cut that piece off for you. I had to do the same thing. They come off pretty easy their just soldered on. Good luck
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
Old 07-06-2015, 07:51 AM   #3
crane.fletcher
Actually I am doing the old fuel tank relocation mod. I have a new tank from LMC trucks, and need the fuel filler neck from the gas cap to the tank. I have not been able to locate an aftermarket. I am hoping to find some good used plumbing. Thanks.
