Old 07-05-2015, 03:31 PM   #1
Zach079xxx
Zach079xxx's Avatar
Exhaust leak
Recently got an exhaust leak, I sound like a 50 caliber getting up to speed. I think its coming from my manifold gasket (I'm hoping). What type of gasket do I need and what brand is suggested? I can't take the pecking anymore. Also I'm going to get the shop to spray them black for the time being until I go another route and get headers. I would do it but I don't wanna break a bolt off and if the shop does its on them.
Here's some pictures.
Zach079xxx is offline   Reply With Quote
Old 07-06-2015, 11:53 AM   #2
albertgen
Re: Exhaust leak
I have a 78 C10 custom deluxe 305, and there were no gaskets on it. I am in the process of removing the manifolds. The only hard part was I had to cut the 6 studs that attach the y pipe. I am putting on new painted manifolds and heat shields plus new spark plug shields. I had a leak too. I thought I's just go ahead and clean up the engine and make it look a lot cleaner. Al
albertgen is offline   Reply With Quote
Old 07-06-2015, 04:49 PM   #3
Zach079xxx
Zach079xxx's Avatar
Re: Exhaust leak
I've heard some have gaskets and some don't. Maybe it's just me but in the second picture I see a gasket..
Old 07-06-2015, 08:07 PM   #4
Super_Dave
Super_Dave's Avatar
Re: Exhaust leak
I had a bad experience with the gaskets supplied by Hedman Hedders; blowouts all over the place. My racing buddy turned me on to Remflex gaskets. Worked great and wouldn't use anything else. http://catalog.remflex.com/
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 07-08-2015, 11:59 AM   #5
GRX
GRX's Avatar
Re: Exhaust leak
Warpage from repeated heat cycles. You can try filling the void with a soft gasket. Proper way would be to have the manifold machined flat. A floor standing belt sander will do.
GRX is offline   Reply With Quote
Old 07-08-2015, 09:27 PM   #6
raceman6135
Dino burner
raceman6135's Avatar
Re: Exhaust leak
No gaskets required.
My 1986 C20 with a 350 engine has the same style exhaust manifold on the passenger's side, that is, the 'log' is above the exhaust ports, next to the valve cover.
When I removed my exhaust manifold to look for the leak, I discovered the manifold itself had a hole in it, hidden under the sheet metal heat stove (which funnels warm air to the bottom of the THERMAC air cleaner).
Not worth it to pay someone to try to weld the cast iron; $20 and a trip to the wrecking yard was the solution.
raceman6135 is offline   Reply With Quote
Old 07-08-2015, 09:32 PM   #7
Zach079xxx
Zach079xxx's Avatar
Re: Exhaust leak
Ok so I'll just run to the junkyard if that's the case! Thanks
Old 07-09-2015, 09:33 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Exhaust leak
I'd look for any manifold cracks/soot,and file mateing surfaces slightly if needed
looks like it had air injection?,check the air injection holes are all plugged,not sure if other spots could blow out but it could sound like that.
i use a spreader if the manifolds don't hand thread in, then leakers get gaskets
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
