Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-05-2015, 06:21 PM   #1
BigDan3131
BigDan3131's Avatar
Dual Use Fuel Pump
With budgets being tight this year I had decided against the twin turbo LSx motor what with all the extra plumbing and so forth and decided and nice mellow 600 something hp BBC.
Do you guys have any experience running some of those dual use electric fuel pumps? The kind that can be used for either a carb or FI? I was thinking about going that route so that in the future I could install the FAST 2.0 System without having to swap out pumps and re-plumb it for FI.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-05-2015, 08:41 PM   #2
71Dragtruck
71Dragtruck's Avatar
Re: Dual Use Fuel Pump
I run a Aeromotive A1000 pump and return regulator, it will support high HP injected or carbed motors.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 07-05-2015, 09:27 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
I also run an Aeromotive with a return regulator . The regulator came with a high and low pressure set of springs .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-06-2015, 03:05 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If you have a good reg like the others mentioned, you can put as much pressure into it as the pump supplies, since the reg will take it down to the desired level for you. Just make sure you don't have one of the low-pressure only regulators, otherwise your good. (and make sure any filters before the regulator are rated for the full pressure!)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-06-2015, 03:46 AM   #5
BigDan3131
BigDan3131's Avatar
Thanks Guys!
