07-06-2015, 12:01 AM | #1 |
Please tell me I'm ok
Got this K5 about a month ago and I guess like everybody else I'm slowly messing with things getting the little things fixed and back working. In doing this I realize the wire on the sending unit for the coolant had a bad connection and was causing my gauge not to read. Now that it's fixed it is showing that the truck is running hot, way hot. I have tried an advanced auto parts radiator thinking that maybe mine was busted (which it does have a small leak at the top of the tank). Well that radiator got really hot really quick so now I'm back to the original four row all brass radiator and it's still reading hot.
I'm hoping that since I've been driving the truck for a month with 60+ mile trips in 85-95° weather and it's never actually what I would consider overheated and steam blowing out of the radiator. Maybe it's one of the sending units with the wrong resistance and the gauges reading inaccurate?? Ideas?? Think I'm picking up an infrared heat gun tomorrow and going to try to get a reading off the thermostat housing or the hot side of the radiator and see what I get. Thanks Daniel
72 K5 4x4, 350(rebuilt stock w/edelbrock carb and manifold)/th350, 4"lift 35's, GM 10bolt rear(not thrilled)... Thinking I need some heads and a mild cam or maybe a 5.3!! |
07-06-2015, 10:18 AM | #2 |
Re: Please tell me I'm ok
check both sides of the block you might find another temp sensor
07-06-2015, 11:30 AM | #3 |
Did you replace/check the thermostat before you swapped radiators? It may be stuck or corroded and impeeding flow. Could also be a bad water pump and it's not putting out enough flow.
72 K5 Blazer - BCHWGN |
07-06-2015, 11:49 AM | #4 | |
When I hit engine with IR thermometer the corner of the rad tank(where the engine coolant enters) I was reading about 196*, at the manifold right below chrome thermostat housing reading about 185*, but now if I shot the temp sending unit(manifold mounted) or right below it was reading 215-220*
07-06-2015, 11:52 AM | #5 |
OK, this may sound like a simplistic question, but when you start the truck, does the temp gauge gradually move to hot, or is it there right away?
If it's gradually moving, I'd echo what others have said and replace the thermostat. If it's reading hot as soon as you turn on the ignition, you've grounded the wire to the gauge. As far as being OK, Chevy small blocks are generally pretty forgiving. Just don't do what my father-in-law did and put a hose in the radiator when the engine is overheated. |
07-06-2015, 12:29 PM | #6 |
Check your water pump as well. If it's not pushing enough flow you will run hot.
07-08-2015, 01:15 PM | #7 |
It could also be the wrong sending unit. They have varying resistances.
Verify with a heat gun or something else to ensure that it is actually running hot. I once watched a guy working on his Ford spend about 8 hours working on it thinking it was overheating, replaced a ton of parts, only to find out the sending unit went bad.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
07-09-2015, 10:55 AM | #8 |
I am noticing that it will climb in temps when I'm coasting, ideling or generally low RPMs but when I get on the throttle the temp will drop..... To me that sounded like could be a weak water pump.....???
07-09-2015, 11:15 AM | #9 |
Sounds like it to me. Could also be poor radiator flow (plugged) and when you increase RPM, you increase fan speed, drawing more air over the fins. Could be either. The water pump is less than $30 and only takes a few minutes to change out. Not so lucky with the radiator, but you should be able to look into the radiator to see if there's a lot of scaling and buildup inside.
07-09-2015, 02:04 PM | #10 | |
07-09-2015, 04:01 PM | #11 |
I had similar problems, I went with a 3 core aluminum radiator and stewart phase II pump. I added (2) 14" electric fans as well, might be overkill but I sometimes sit in a lot of beach traffic in the summertime and the fans make a big difference.
Good luck with the diagnosis, sounds like you are on the right track and have some great minds on the forum to help you along the way. |
07-09-2015, 04:02 PM | #12 |
Don't forget increased air flow over the coils can drop temp when you're moving.
07-10-2015, 02:45 PM | #13 |
IR gun is a the right tool. Doesnt sound like exhaust gasses are making their way into the coolant circuit - usually you cant keep coolant in the radiator when that happens, unless its a very small leak. Might be running lean - check carb jetting and timing.
07-10-2015, 08:56 PM | #14 |
Does it have a fan shroud? It should, and the fan blades should be about half in the shroud.
You might replace the belts since there may be slipping and chances are they need it. |
07-10-2015, 09:25 PM | #15 |
sounds like you belt is lose,when you throttle up belt tightens up,
07-10-2015, 11:59 PM | #16 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Fan shroud will make a BIG difference...especially at low speed.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
07-11-2015, 11:54 AM | #17 |
It has a shroud.... Think I got the temp good to go now, all new coolant and a 180 thermostat. So far it's hoding up fine. Thanks for all the help
07-11-2015, 05:23 PM | #18 |
What did you do to fix it?
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
07-11-2015, 07:38 PM | #19 |
Think putting the lower thermostat helped the most, still think it's gets hotter than it should but then drops and stays pretty decent
07-12-2015, 02:09 AM | #20 |
I don't think 195 is very hot. That's stock operating temp for the later model V8. I run mine at 195-210 with electric fans and fuel with fuel injection. Its probably just fine.
