Old 09-06-2003, 07:50 AM   #1
reefermadness
Question Alternator Wiring ?
Question?
I am replacing my old alt. with an internally regulated one, I know that the stator side needs power when the key is on (I took the ignition hot from the old voltage reg.), but what do I run on the field side. The guy at the parts store said to just run a jumper from the alt. batt. wire, but that don't sound right to me. Thanks
reefermadness is offline   Reply With Quote
Old 09-06-2003, 10:49 AM   #2
jose
jose's Avatar
Here is some info from GMC Pauls site .
http://www.hostboard.com/cgi-bin/ult...ic&f=349&t=701
68 GMC 4x4 SWB
jose6772@yahoo.com
jose is offline   Reply With Quote
Old 09-06-2003, 08:49 PM   #3
ddsmith
Glowing since 1978
ddsmith's Avatar
Just did this today. Went from a one wire alternator to the normal internal regulated alternator. I chose to connect the Red to the Blue wire with a butt connector and the Brown to White wire with a butt connector. Bought the connector at Advanced Auto. They call it an extender. It has a Red and a Black wire on it. I call it my new alternator plug. I removed the wires from the extender keeping track of where the Red wire was on the extender. I then placed a Packard 56 type connector on the Blue wire and put it in the plug in the spot the Red wire use to be. I did the same with the white wire and it almost looks stock. I bought an alternator for a 75 C20. I required some shims on the bottom bracket. I used washers to take up the gap. The two halves of the alternator were 180 degrees out. I removed the pulley/fan from the shaft and removed the four bolts holding the halves together. I used a screw driver to pry the front half up high enough to rotate it to the new orientation and bolted it back together. Care should be exercised when doing this to prevent the back half from separating unless you enjoy reinstalling those brushes.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
