Old 07-06-2015, 06:38 PM   #1
SkinnyG
SkinnyG's Avatar
DIY TH350 Governor Calibration
Lots of talk of doing this online. VERY few pictures. Here's what I did to my '77 Silverado....
I finally bought the MSD Tach adapter (8920) to make my tach work with an MSD box, and discovered WOT shifts were occurring at about 3800rpm. I knew it was shifting early, but wow. The cam should be good to 6000rpm (231°@050", 0.470", 108°LSA, 104°ICL, 10.9:1). Gotta change the governor weights.
Governor came out, and I bought a small box of 6d nails. These nails were just a tick too big in diameter, so I drilled the holes #40 so the nails would fit dandy. This is just a baby fart larger. Wonderful manufacturer's tolerances.
OEM Weights are 0.062" thick.
I removed the governor weights and marked them 1/2" from the end, and 1/16" off each side. Ron Sessions' TH350 book says grind no more than 1/2" down, and 3/16" in. I figured I'd do this in stages - it's harder to put metal back.
Then ground them down, and de-burred.
I didn't even install them yet. I decided to get more aggressive.
This is now 5/8" off the end, and 3/16" off the sides.
This brought the shift point to about 4800rpm. More grinding is in order.
I did not change any springs - most folks online have had the best success using the original springs.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-08-2015, 12:59 PM   #2
MikeB
MikeB's Avatar
Re: DIY TH350 Governor Calibration
I did the same mod many years ago to the TH350 in my 69 C10. It bumped the WOT shift point to around 4500, as I recall, which was perfect. When/if I wanted it to rev higher, I'd just hold the trans in gear.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
Old 07-08-2015, 02:32 PM   #3
Brent7654
I used a B&M kit a few years back when I was doing a lot of bracket racing, set it up to shift from 1-2 at 6800.
Was deadly consistent at the track.
I always shifted 2-3 manually as it would depend on the race, but 2-3 shift was slightly lower at full throttle 6500.
Kit was cheap for the results you get. Came with springs and weights and directions for approx shift rpm's...
Brent.....
Brent7654 is offline   Reply With Quote
Old 07-08-2015, 06:54 PM   #4
cadillac_al
A nice low buck mod, gotta love it. How does it feel in normal part throttle driving and around town?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-08-2015, 08:37 PM   #5
68Timber
I know the pieces fit
68Timber's Avatar
Thanks for the pics, I'd noticed as well guys say it's pretty easy but nobody ever shows a pic of what they did.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-08-2015, 09:11 PM   #6
MikeB
MikeB's Avatar
I don't recall anything different under part throttle driving.
Informative article on shift points here: http://yarchive.net/car/transmission.html
Mike
Old 07-09-2015, 12:52 AM   #7
SkinnyG
SkinnyG's Avatar
Changing WOT shift points from ~4000 to ~5000 had a noticeably affect on part-throttle shifts, probably because of how I have the vacuum modulator set. If I dial the vac.mod back down, there should be no noticeable change.
Soon I will change one weight to a wedge point, and see what it does. If that's not enough, then I will grind the other weight to a wedge point. Then pin points will be next. Then maybe drill holes.
Old 02-09-2022, 09:27 PM   #8
SkinnyG
SkinnyG's Avatar
Just a follow-up. It's been over six years now, and I have made no changes to this at all.
Old 02-10-2022, 02:32 PM   #9
TrailerTrash
TrailerTrash's Avatar
I have been trying off and on to get my TH350 dialed in for the last few months. I used this thread for reference many times until I was comfortable with the process. I appreciate the info you provided.
Mine was shifting at 4,000 exactly. I trimmed a little then I trimmed alot and got to 4800. Then I decided to take one spring out. Dont do that lol. I trimmed even more and it is right at 5,000. I am thinking about tapering the tip and drilling a few holes to get around 5200/5400
It really isnt fun getting that cover off and back on
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
