Old 07-06-2015, 07:48 PM   #1
Bass66C10
Truck shaking in 1st gear
My 66 shakes when I start off in first gear, second and third are smooth. I already replaced the (yoke) on the drive shaft.
Bass66C10 is offline   Reply With Quote
Old 07-06-2015, 08:11 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Truck shaking in 1st gear
You probably need to have the flywheel turned.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-07-2015, 06:42 AM   #3
PGSigns
PGSigns's Avatar
Yup sounds like some clutch work is in your future. Surface of the flywheel is no longer flat. Best fix is to have the flywheel surfaced if it is not to badly heat cracked and to put a fresh clutch in it. Here is a like to a thread here that shows a good picture of a toasted flywheel.http://67-72chevytrucks.com/vboard/s....php?p=5906610
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-07-2015, 07:23 AM   #4
vince1
If you have any drips coming from that area it could also be caused by oil on the clutch.
vince1 is offline   Reply With Quote
Old 07-07-2015, 10:11 AM   #5
Bass66C10
I know my oil pan is leaking, I have the new gasket, just have not had the time to install it yet.
Old 07-07-2015, 10:51 AM   #6
1963c-10
1963c-10's Avatar
Hey Bass66C10.....welcome from Fayetteville NC and to the forum. Have you dropped the inspection plate and looked at the condition of the flywheel yet? I agree with the above though, sounds like a combo of an oil leak and flywheel needing machined or replaced.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-07-2015, 11:09 AM   #7
RKS0069
RKS0069's Avatar
Hi. My truck would shake a lot in second gear (don't use first) turned out the issue was that the front transmission mounts were a little soft, changed them out and all is good now. Very good chance you are just having clutch issues though. Hope you getter fixed soon.
RKS0069 is offline   Reply With Quote
Old 07-07-2015, 01:23 PM   #8
61K10
61K10's Avatar
mine shakes a little and clutch/f/w is all new, not rebuilt. everything is rebuilt trans tf/case to rear even the rear axle. I have leaf springs as well, which are org. which probably need a rebuild. Like RK said not only the clutch will cause this.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-07-2015, 01:54 PM   #9
padresag
centre supports also will give that sensation if you have a 2 piece d/shaft. the rubber part will be collapsing. under throttle pressure esp in the lower gears where the torque multiplies you will feel it
ron
padresag is offline   Reply With Quote
Old 07-08-2015, 01:26 PM   #10
Fla Grown
Fla Grown's Avatar
I have the same issue. When I first got the truck 5 years ago it had the original 250 with a 3 speed trans and always shuttered in 1st. I pulled the engine to reseal the engine and replace the piston rings. Had the flywheel turned and put a new clutch in at that time. Still shuttered. Thanksgiving of last year I bought a built 250 from Tom Langdon and installed the same flywheel and clutch. Worked smooth for about a week and then the shuttering came back. I drive it every day 70 miles round trip. If I park it for a few days and drive my H3 it wont shutter for a day but it always comes back. Sounds like I need a new flywheel and clutch as well!
I have replaced the carrier bearing and universal joints as well.
Fla Grown is offline   Reply With Quote
Old 07-08-2015, 03:21 PM   #11
Bass66C10
Thanks, I am going to try and look at the flywheel this evening and see what it looks like
Old 07-08-2015, 08:25 PM   #12
c20 diesel
Had same problem years back. new clutch turned flywheel still shake AKA clutch chatter. first & reverse. problem was motor mount & mount on bell housing bolts loose one bolt had fallen out. fix mounts problem went away.
c20 diesel is offline   Reply With Quote
Old 07-08-2015, 11:34 PM   #13
Mackie
Mackie's Avatar
A good test for motor mount problems is to have someone rev the motor while you watch for the motor to lift or twist.
If you trust them have them try to drive ahead slightly with the e brake set while you watch.
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 07-09-2015, 11:58 AM   #14
61K10
61K10's Avatar
I have some urethane ones sitting, might put them in and see if any difference. you have to remember my eng has a horse-shoe ft mount not side mounts. I had a 62 V8 lfb years ago and it was butter smooth while taking off. My clutch is a cheap 11" zoom, maybe if i bought a $$$ center force clutch??
1961 chevy K10
Old 07-09-2015, 12:13 PM   #15
1976gmc20
No need for a second person. The floor gear shift will tell you
I've been alerted to motor mount problems twice now by the floor shift moving sideways in low or reverse under a heavy load.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 07-10-2015, 03:23 AM   #16
luvbowties
luvbowties's Avatar
Cool Re: Truck shaking in 1st gear
...seen 'em do it when bell housing-to-block bolts were loose...
Sam
luvbowties is offline   Reply With Quote
