Old 07-06-2015, 11:54 PM   #1
RebelSoldier
RebelSoldier's Avatar
Ls swap question
I am thinking about doing the LS swap on my 84 stepside. I want to use the original gas tank LOCATION, does anyone know of a place that makes factory tanks with the fuel pumps required to get the 58psi pressure to get the motor to run correctly? Or what the best fuel pump to buy would be. I am thinking of using the 87 tank. I am open to all suggestions and opinions.
RebelSoldier is offline   Reply With Quote
Old 07-07-2015, 12:39 AM   #2
UKNOWME
UKNOWME's Avatar
Re: Ls swap question
I've heard of that option but am curious to know as well.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 07-07-2015, 12:46 AM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Use a 1987 tank, 1987 sender and Delco/Delphi EP381 pump. Use the corvette fuel filter/fuel pressure regulator. This is what I'm running on my 85 with a 4.8.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 07-07-2015, 01:44 AM   #4
2wd73blazer
I believe the sender and tank from a 87 and a ac delco ep381 would work.
2wd73blazer is offline   Reply With Quote
Old 07-07-2015, 02:06 AM   #5
Mikec10
Mikec10's Avatar
Im doing this swap, i opted to buy a 87 tank and fuel sending unit with a modern oem replacement pump. FYI 87 16 gal tanks are not baffled contrary to my belief.
im using the stock return system
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 07-07-2015, 08:02 AM   #6
bnoon
I used the stock tank, added an in line low pressure side filter, an external pump from Amazon rated at 255 LPH (cost $45). Stock type replacement 3/8 anf 5/16 steel hard lines that I bent to run up the firewall and compression fittings to the stubbed out 2001 rails and stock 2001 fuel pressure regulator.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 07-07-2015, 10:47 PM   #7
RebelSoldier
I appreciate all the responses. I think I will get the 87 tank and go from there.
Old 07-08-2015, 10:54 AM   #8
OutlawDrifter
this is the easiest and most correct way!
make sure you don't cheap out on the pump only buy genuine delco or delphi. do it one time!
to make the search easier on the fuel filter, just look up one for a 2005 corvette.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 07-08-2015, 11:05 AM   #9
Wgesnerjr
Wgesnerjr's Avatar
I am going with the 87 tank as well for my swap. The reason is the sump in the tank for fuel injection will work well in my 5.3 swap.
Just in case anyone else wants to know why the 87 tank is good for this purpose, I got a real good picture of the sump looking through the filler neck opening. Kinda looks like a baking pan for bread. Looking down through the sender opening, you can see two holes in the bottom that lets fuel into the sump.
Found mine (20 Gallon for a long bed) on eBay for just under $75 with free shipping. Just do a search and look for the best price. I got mine from am-autoparts.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-08-2015, 07:50 PM   #10
RebelSoldier
Does the Delco EP381 pump, make the 58psi that you need for the LS? Just want to verify.
Old 07-08-2015, 07:51 PM   #11
RebelSoldier
Does the delco EP381 pump make the 58 psi required? just making sure
Old 07-08-2015, 09:15 PM   #12
OutlawDrifter
Yes
1991 Z/28, 6.0L/T56
Old 07-09-2015, 03:11 PM   #13
bnoon
If you're doing a stock swap, then yes, that way will work. For a lot of power though, the Corvette filter/regulator is a restriction and the Delco/Delphi pumps don't flow enough. And it's not the easiest at all.
Old 07-09-2015, 03:58 PM   #14
OutlawDrifter
my camaro puts down 428rwhp and uses a corvette filter, that's over 500hp at the crank. granted i have a different fuel pump, but it takes some serious power for that to be an issue.
the delco pump will safely power 400 hp.
1991 Z/28, 6.0L/T56
Old 07-11-2015, 12:22 AM   #15
rs74
rs74's Avatar
Good question. I am going to be running into the same thing shortly. Although my issue is that I had already bought new tanks and senders for my 85 before making the final decision to go LS. I am looking at a 5.3l and would like to be able to use both tanks. I was planning on doing a cam and headers with tune so not sure how or what I am going to do from here.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 07-11-2015, 03:32 PM   #16
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Read my 87 LS build, or Glock's or Dennis's....all questions are answered in these and among all the other LS build threads if you do some digging.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
