Old 07-07-2015, 02:47 PM   #1
RustyBucket
RustyBucket's Avatar
C.L. '69 C10 LS project $2k obo
http://spacecoast.craigslist.org/cto/5105244250.html
not me but interesting
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 07-07-2015, 02:55 PM   #2
Aruba1
Re: C.L. '69 C10 LS project $2k obo
Offer $1500 and go get her. If the 6.0 turns out fine you would have done really well. A 6.0 is at least a $1000 engine all day long, some go for $1500 and up. The NV4500 is at least $600. Clutch and special flywheel (depending which flywheel was used) will set you another $500 minimum. I would be interested to find if the driveshaft is hooked up, that will save you $200 to have it shortened and balanced. You will still need a harness (if he does not have one) that will run you about $600. I just finished doing my conversion (5.3L with NV4500) and I have about $1800 in the engine and engine parts alone, not counting the transmission and driveshaft shortened.
Aruba1 is offline   Reply With Quote
Old 07-07-2015, 03:00 PM   #3
67 chevelle
67 chevelle's Avatar
sounds like a deal , but anyone can dump a non running ls "in the hole" ,of a very ruff truck ,, thats a whole lot of "project" , like everything.
Looks like the guy pulled out the sb and thew it in there from quiet a distance
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-07-2015, 03:24 PM   #4
hugger6933
Well if the motor wasn't wired it most likely wouldn't have the UBEC sitting on the fenderwell. If the drivetrain is good then you would def be ok. jim
hugger6933 is offline   Reply With Quote
Old 07-07-2015, 04:20 PM   #5
boraxman
Keepin an eye out
boraxman's Avatar
Looks like a roll of the dice/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 07-07-2015, 04:53 PM   #6
Aruba1
And big reward awaiting if the engine turns out good and little reward if the engine is bad. Worst case it's still money to be made if he takes $1500.
Old 07-07-2015, 10:13 PM   #7
dukkie
My Spoon Is Too Big
dukkie's Avatar
Verify by looks alone, is that not the cover of a 4.8/5.3 and NOT a 6.0 ?
am I incorrect?
6.0
1972 C20, 03-14-10 Build Thread
2000 Silverado 4.8L, 11-04-13 (Currently Parting)
1999 Silverado 5.3L, 07-07-14. (Engine Donor)
2015 Ram 05-20-15 (Daily Driver)
dukkie is offline   Reply With Quote
Old 07-07-2015, 10:33 PM   #8
indymachinist
Well an iron headed 6.0 ls engine is older. I believe 99 and 00 only. So that may just be an older style of plastic cover. Nor sure honestly. I am pretty sure the older iron headed 6.0 engine also has a longer crank shaft as it was intended to run with a 4l80e trans only. Later year 6.0 engines used a spacer with the 4l80e instead of a longer crank.
indymachinist is offline   Reply With Quote
Old 07-07-2015, 10:40 PM   #9
leddzepp
Moderator
leddzepp's Avatar
X2. Non running engine = boat anchor.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 07-07-2015, 11:21 PM   #10
Aruba1
If I am not mistaken the 6.0L did not come with aluminum heads till 2001. The engine cover is for a Vortec 4.8, 5.3 and 6.0 from 1999 to 2002 in the silverado, sierra, tahoe and yukon. I had to ebay Vortec 6.0L engine cover to find out as my 2000 5.3L did not come with one, but these were put in other vehicles too and cover may look different.
Old 07-08-2015, 07:28 AM   #11
71sierragrande
Petroleum User
71sierragrande's Avatar
I had a 2004 escalade with the vortec 6.0. The cover had "VORTEC 6000" printed on it. Strong engine
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 07-08-2015, 09:31 AM   #12
indymachinist
Your 04 escalade engine was a better engine than this older one.
Not to say that this one is bad it's just not as powerful.
Old 07-08-2015, 09:41 AM   #13
jackyl9999
jackyl9999's Avatar
I am always afraid of "projects". Sometimes there is a reason they stopped working on them.
That truck looks like it has been sitting for awhile.
1500 is the absolute max I would offer. I would offer less.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
