07-07-2015, 07:13 PM | #1 |
Look at this shaft
My steering pitman shaft splines looks mashed. Should I replace it?
Pat 1949 unmolested Indy Farm Deluxe AD 1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544 |
07-07-2015, 07:44 PM | #2 |
Re: Look at this shaft
I've had Worse Fwiw.
I Think it is still Usable, But Others might say No! Allen |
07-07-2015, 07:56 PM | #3 |
Usable yes, but as readily available as boxes/shafts are I would look for one. Shouldn't be that expensive.
55.1 GMC Suburban Hydramatic |
07-07-2015, 08:14 PM | #4 |
Hollister Road Co.
That's a twist in the shaft from an accident or hitting a hole, this is fairly common and I see it often in boxes I take apart. The twist will have fractures in it so I'd replace it. NOS ones are around and as said plenty of used ones as well
07-07-2015, 08:32 PM | #5 |
In the manual the same unit fits 1/2, 1. and 1 1/2 ton but the ones for say 1 1/2 to 2 Ton. Weird. Anyone know what the correct part number for a 1/2 ton is?
07-07-2015, 08:55 PM | #6 |
hit a hole?
isn't a hole a void surrounded by matter? perhaps you did not hit a hole but a whole lot of something? |
07-07-2015, 09:11 PM | #7 |
I would, it looks like that truck took one serious hit at some time or at least the truck the steering box was in at the time did.
07-07-2015, 09:35 PM | #8 | |
Hollister Road Co.
07-07-2015, 10:47 PM | #9 |
IOW, it's toast.
07-08-2015, 04:52 AM | #10 | |
07-08-2015, 07:13 AM | #11 |
I will change it out. Anyone know the correct part number to order?
Thanks Pat
07-08-2015, 09:16 AM | #12 |
Hollister Road Co.
Pat. send me an email I have this one that should work, it has the bushings with it
07-08-2015, 10:27 AM | #13 |
There ya go, nos with bushings.
I think I'd check the rest of the steering box over real close to make sure That there was no more damage that you didn't see at first inspection before going further with it though. A hit hard enough to bend the shaft may have damaged other internal pieces.
07-08-2015, 10:50 AM | #14 |
Looks to be longer than the one I pulled. I'm thinking the part number is 3847342 for the commercial trucks. 1/2 Ton should be included.
07-08-2015, 10:52 AM | #15 |
I broke down everything to the ball bearings and checked. Looks good all around except for the shaft.
07-08-2015, 02:09 PM | #16 |
Good enough.
07-08-2015, 02:40 PM | #17 |
I will use a oil seal in place of the packing when I rebuild it.
07-09-2015, 12:41 PM | #18 |
Still no luck finding a used or reasonable priced replacement
Posted via Mobile Device |
07-09-2015, 01:16 PM | #19 |
Post over on oldgmctrucks.com or stovebolt.com. I'm sure you'll come across one quick. Also, there is Tom Myer's in OK (918) 542-3871 (truck salvage) and a guy out in Idaho that is parting out a large number of truck. His name is Gary Severance #208-683-2393. (he has some CL ads in the NW)
I've bought quite a few parts from Gary over they years. He doesn't do email and may require payment via money order/certified check. Great guy, old school and pretty much has anything you could ever need (except hydramatic parts, myself and one other guy bought him out on what he had). Prices are very reasonable, as is his shipping (at cost).
07-09-2015, 02:41 PM | #20 | ||
Holes aren't filled with matter? Quote:
Craigslist?? Last edited by 1project2many; 07-09-2015 at 02:55 PM. |
07-09-2015, 03:13 PM | #21 |
Hollister Road Co.
I came up empty on this one, The part number fits 47-54 1/2 through 1.5T so you have a wide range to shop in
07-09-2015, 03:59 PM | #22 |
Agreed. Thanks for looking.
07-09-2015, 07:41 PM | #23 |
put a wanted ad on craigslist!
07-15-2015, 06:55 AM | #24 |
Found one on Ebay that was sitting on the shelf or in a moist area. Was covered with surface rust. Cleaned it up. No on to the next part needed.
