07-07-2015, 07:30 PM | #1 |
power steering gearbox
I put the power steering unit from my 66 c-20 parts truck into my 66 c-10. i am being told i need to change the gear box to a power steering gearbox. the ratios are different. any input. do i need a power steering gearbox or a c-20 gearbox
07-08-2015, 01:09 AM | #2 |
60-66 Nut
Re: power steering gearbox
I think we need to clarify a couple things here. Is the power steering you installed in your C10 from a C20, the original style power assist steering? If so I believe the C10 unit is the same as a C20 unit. I do not understand this sentence "do i need a power steering gearbox or a c-20 gearbox" A steering box is the same whether it is for a C10, C20 or C30. It is either a manual steering box, or a power steering box. In my opinion the '68+ integral power steering box is a better way to go for power steering.
07-08-2015, 12:56 PM | #3 |
I think he is asking if the manual box is the same box used with the power assist good question. sorry i don't know.
1961 chevy K10 my build is------------61K10 build |
07-09-2015, 12:52 AM | #4 |
60-66 Nut
The steering box is the same between the manual steering and the power assist. Just the pitman arm is different.
07-09-2015, 11:41 AM | #5 |
thanks capt for clearing that up. should put that in the p/stearing facts.
07-09-2015, 12:34 PM | #6 |
