07-08-2015, 10:17 AM | #1 |
1971 K5 , Broke Front Axles Help, interchange.
both fronts are broke at the u-joints.... Have heard from a few people you can use newer ones? same spline??? upgrade??? there an interchange chart?
Any help would be appreciated ! Thanks.
1970 chevelle 1971 blazer 1972 c20 custom camper 1931 ford A coupe. |
07-08-2015, 10:24 AM | #2 |
Re: 1971 K5 , Broke Front Axles Help, interchange.
73 up will swap right in. I have always used them in mine. They use a bigger joint and are a beefier axle.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
07-08-2015, 10:30 AM | #3 |
nice!!! so if i have3 some out of a 79 k10 they will swap in?
07-08-2015, 12:18 PM | #4 |
79's would be from a 10 bolt axle and the inner axles won't fit a Dana 44. The outer stub axle will fit though. From what I have seen, they started using the bigger axle joints in mid 72. In mid 77, they started using 10 bolt axles.
07-08-2015, 12:21 PM | #5 |
YES... I JUST NEED OUTERS.... SO I SHOULD BE GOOD!!!! Thanks!!!
07-08-2015, 03:18 PM | #6 | |
From late 72 (2nd design) up through 1991 in the blazer and suburbans took the larger joint, 44 and 10 bolt |
07-08-2015, 03:22 PM | #7 |
yes but worst case i can get adapter joint... i just have the 79 outers already.
07-08-2015, 03:37 PM | #8 |
One of the First
I have a set of OE 72 axles inner and stub. excellent condition... LMK
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
07-08-2015, 05:55 PM | #9 |
07-09-2015, 08:57 AM | #10 |
07-09-2015, 01:05 PM | #11 |
One of the First
This might help:
http://67-72chevytrucks.com/vboard/s...d.php?t=670179
