Old 07-08-2015, 07:28 PM   #1
Nordic
Nordic's Avatar
cpp caliper question
On my 1958 I used CPP 6lug disc brake conversion, I need to replace the left caliper and there is no numbers or casting marks, Does any one know a part number for a replacement? I do not want to order an other one from CPP,
Thanks,
Nordic
Nordic is offline   Reply With Quote
Old 07-08-2015, 08:28 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: cpp caliper question
There are 2 designs commonly used the newer one is from an 85-90ish S10 it is not as long as the other which is 71-87 Fullsize chevy truck. The caliper is a bit larger. You should take it to the parts store and with the above mentioned it will be no problem matching it up.
Jurassic-1 is offline   Reply With Quote
Old 07-09-2015, 11:46 PM   #3
roger55
roger55's Avatar
I have that kit. It's the one for the full size chevy truck.
roger55 is offline   Reply With Quote
Old 07-11-2015, 06:53 PM   #4
Jurassic-1
Jurassic-1's Avatar
Did you find a caliper?
Old 07-11-2015, 07:07 PM   #5
roger55
roger55's Avatar
All the discount Auto Parts stores keep those in stock.
Old 07-11-2015, 08:24 PM   #6
Nordic
Nordic's Avatar
Yes Advance auto 1972 chevy pickup caliper
Thank for the info.
Old 07-11-2015, 08:26 PM   #7
OrrieG
OrrieG's Avatar
Make sure you get the correct side with the bleeder on the top. They will fit either way, but almost impossible to bleed with the bleeder on the bottom. I know from experience....
OrrieG is offline   Reply With Quote
Old 07-11-2015, 10:43 PM   #8
Jurassic-1
Jurassic-1's Avatar
Yes I agree and there should be a L and R molded into it.
