Old 07-08-2015, 09:04 PM   #1
aod92
aod92's Avatar
Steering wheel install. Please help!
I'm reinstalling my steering wheel and it's taking a lot for the nut to get tight. I'm using an impact and its compressing the spring on the outside of the column really tight. Is that right? I don't remember the spring being that compressed before. The steering wheel felt loose till I got it to this point. Your help is appreciated. Last thing I need is for my wheel to fall off driving down the street!
aod92 is offline   Reply With Quote
Old 07-08-2015, 09:05 PM   #2
aod92
aod92's Avatar
Re: Steering wheel install. Please help!
Old 07-08-2015, 11:16 PM   #3
jocko
jocko's Avatar
should not need an impact. not sure what you mean by it's not getting tight(?) if it's compressing that spring there has to be some resistance, yes? more info pls and maybe we can help.
Old 07-09-2015, 06:13 AM   #4
aod92
aod92's Avatar
The steering wheel feels like it should now that I've used the impact. My question is should that spring be compressed as much as it has? Is that normal? how much do you normally have to tighten the steering wheel nut?
Old 07-09-2015, 06:47 AM   #5
aod92
aod92's Avatar
It just feels like it's gonna keep on tightening until the spring is fully compressed.
Old 07-09-2015, 07:14 AM   #6
chevy88
chevy88's Avatar
That nut just tightens the steering wheel hub done onto the splined shaft, the nut should eventually snug the wheel hub onto the shaft, you shouldn't have too worry about that spring being compressed, just make sure it tightens down and wheel hub is tightened down on to top part of splined shaft.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 07-09-2015, 08:24 AM   #7
aod92
aod92's Avatar
One more thing. I don't have the steering shaft installed to the steering box yet. So it keeps compressing the spring because it has nothing giving it resistance. Should have I installed it to the steering box first?
