Old 07-08-2015, 11:41 PM   #1
jason999
Turn Signal Assemblies Falls Out of Hood
Here is a really simple question. On my 1966 C10 both of my turn signal bulb assemblies fall out of the turn signal lens housing assemblies, when I close the hood. These are the newer white bulb assemblies from Oreileys, btw.
Am I missing a step for installation or what?
If not then I am going to engineer something to keep them in place. Any great ideas?
Thanks,
Jason
jason999 is offline   Reply With Quote
Old 07-09-2015, 12:35 AM   #2
Jurassic-1
Jurassic-1's Avatar
Re: Turn Signal Assemblies Falls Out of Hood
Is it the bulbs or the whole lamp bezel?
Jurassic-1 is offline   Reply With Quote
Old 07-09-2015, 12:56 AM   #3
jason999
It's the white plastic fittings that hold the bulbs and slide upward into the holes in the hood.
Old 07-09-2015, 01:20 AM   #4
Jurassic-1
Jurassic-1's Avatar
king at the assy manual the inner housing bolt inside the hood and the metal trim bolts outside. Any photos of it?
Old 07-09-2015, 08:23 AM   #5
1963c-10
1963c-10's Avatar
There is a slot on the fitting that has to be lined up on the housing or it will not seat all the way. The notch will go towards the hood.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-09-2015, 08:40 AM   #6
jason999
Thanks,
I pushed it in with the notch lined up, and seated it all of the way,but it still falls out.
You would think that it would have an adjacent slot and notches on the assembly so you could line it up, push it in, and turn it.
I have the dorman 85818 fitting....It had those before and I replaced them with the same thing. Are they correct?
Old 07-09-2015, 09:22 AM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
you say that they slide upward into the assemblies?
are your housings in upside down, because the bulb assembly should plug into the top of the housing.
Old 07-09-2015, 09:38 AM   #8
1963c-10
1963c-10's Avatar
Good eye Jon......make sure the holes face towards the top of the hood.
Hood is upside down here...but good reference pic on the assemblies installed
Old 07-09-2015, 09:39 AM   #9
1963c-10
1963c-10's Avatar
Originally Posted by jason999 View Post
Thanks,
They look correct....and the part # shows correct from Dorman.
Old 07-09-2015, 09:56 AM   #10
63burban
Chevy addict
Have you oiled your hinges and latch assembly? Don't slam the hood?
I have watched this happen time and again.
I have seen reproduction sockets that are all steel, not plastic, not sure where to get them though.
63burban is offline   Reply With Quote
Old 07-09-2015, 10:04 AM   #11
Jurassic-1
Jurassic-1's Avatar
Now I understand the problem. The socket is falling out. You should be able to push straight in after lining up the slot . Make sure you did not break the clips or bend the metal contacts.
Old 07-09-2015, 10:05 AM   #12
1963c-10
1963c-10's Avatar
I probably have some OEMS ones I can send you if the problem persists.
Old 07-09-2015, 11:04 AM   #13
cg285
he most likely has his lamps on upside down
cg285 is offline   Reply With Quote
Old 07-09-2015, 11:19 AM   #14
HappyHooligan
HappyHooligan's Avatar
I have only had this happen one time, never thought about the lamps being upside down!!
I'll be turning those over next time im playing under the hood.
Hooligan
The Green Hornet
1960 Apache 10 Long Fleet - Driver and Work In Progress
The Death Star
2006 Vstar 1100 - Chopped, Bobbed, Riding the Dark Side
HappyHooligan is offline   Reply With Quote
Old 07-09-2015, 02:02 PM   #15
jason999
You are exactly right! I knew that there had to be something that I was missing. The housing were already in place when I got the truck and I have never messed with a truck like this, so I had no idea.
I'm going to go resituate them in a while.
Thanks a lot
Old 07-09-2015, 02:08 PM   #16
jason999
Thanks you very much for the offer and thanks to everyone who posted.
I wonder if these are occasionally installed upside down by other, like mine were. I knew there was something odd that I was missing when I couldn't find information on google!
Old 07-09-2015, 02:46 PM   #17
1963c-10
1963c-10's Avatar
No problem and an easy fix. Be careful when removing the 2 screws that hold the housing on....there are nuts welded in the hood and I have seen them snap off. I'd spray them down and just go easy on them. Shouldn't take more than 5 min to reverse them.
