Old 07-09-2015, 05:25 PM   #1
yoshi
yoshi's Avatar
Bed wood
As I only had 7 bed strips I decided to fit 8 boards instead of 9, I bought the wood as per http://www.classicheartbeat.com/bed_wood.htm but when I fitted them after varnishing them I ended up with a 1 3/4" gap. I replaced one of the side planks with a 6" wide piece instead. Adding up the widths of 9 boards = 46 7/8", 8 boards = 47 1/2" & mine = 49 1/4"
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 07-10-2015, 04:12 PM   #2
joedoh
joedoh's Avatar
Re: Bed wood
well aside from the extra 1/2" between boards missing from the strip you didnt have, I am stymied. but why wouldnt you fit them up before varnishing?
I just made my own bed floor in my 65, it has a raised floor an widened tubs so a standard short fleet kid wouldnt have fit. I started in the middle and worked my way out, making boards as I went, and ended up with 4" boards on the outside.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-10-2015, 05:52 PM   #3
yoshi
yoshi's Avatar
Re: Bed wood
Ah nobody mentioned the 1/2" gap between em!
yoshi's 49 project
Old 07-11-2015, 11:45 AM   #4
oldman3
oldman3's Avatar
Re: Bed wood
yoshi, Will try and give you some more info about the bed wood. Hope this helps.
Your eight boards should be 47-1/2" as shown on attachment you showed above. With room for 1/4" carriage bolts thru the strips, with approx 5/16" between the boards, this will give you 50", which is the bed width.
The first pic shows my bed (not a good pic) starting from the left side with 4-1/4" board under the angle against the bed, then a 7-1/4" board, then 5" board, then 7-1/4" board and another 7-1/4" board, the 5"board, the 7-1/4" board and last 4-1/4" board under the angle against the bed.
The second pic is of another truck, but here you can see the grooves in the wood boards where the strips should lay. This helps to keep the boards in line for spacing.
I also posted on another thread about how to bolt the bed to frame. How the bolts go thru wood, cross sills, blocks and frame. You can also read that which may help. Here's the link http://67-72chevytrucks.com/vboard/s...d.php?t=667704. Hope this helps..Jim
oldman3 is offline   Reply With Quote
Old 07-11-2015, 04:44 PM   #5
joedoh
joedoh's Avatar
Re: Bed wood
here is the mar k tip sheet I used
http://www.mar-k.com/catalog/pdf/ins...ood_boards.pdf
Old 07-11-2015, 07:01 PM   #6
pvienneau
pvienneau's Avatar
Re: Bed wood
+1 MarK is the bomb
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
