what type of switches for airbags?
hey guys..
i pretty much have everything I need for my bag setup and the last part is now the switches. I was hoping you guys can guide me through on what type of switch to get. I currently have an 8 valve setup and was looking at getting the universal dual gauge plate and adding either the rocker or push button switches. This seems to be A LOT cheaper than getting an actual remote switchbox. Questions: - am i suppose to get a 2 or 3 prong switch? - since i will be have 2 switches per side, do i wire both the left and right inflate to one switch and the left/right deflate to the 2nd switch? - also i need a toggle switch to connect to the key switch for on/off - do I get the 2 or 3 prong one? Thank you! |
Re: what type of switches for airbags?
Have you looked at http://www.avsontheweb.com/avs-switchboxes/
#3 | |
Posted via Mobile Device |
Never Ending Projects
I think he was pointing you to using a pre-made switch box. Honestly if you don't know the correct switch you already need, you are likely not electrically savvy enough to build your own. Not trying to put you down but wiring on this level is not for beginners, if you want a reliable system. Buy a pre-made switch box and you'll likely have a lot less problems.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#5 | |
The 3 prong will give you up and down for one bag, basically the center is power in, then power to the valves on the other two. That will give you up and down on one switch. The 2 prong switch can only work one valve.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#6 | |
Yeah i would just buy a switch box prewired but im lazy,Yeah 2 prong is a one way switch while a 3 prong is 2 way switch.
Thanks you guys! I appreciate all the feedback and yes as much as I mess up its also what I have learned too. I can tell you I have never done any electrical work but am halfway done with my airbag instal. Can wait to post it up soon!
I know this is a different forum but give it a read http://www.s10forum.com/forum/f125/h...wiring-436980/ it has some pictures that will help you in the install.
