Old 07-09-2015, 07:10 PM   #1
hotrod66
hotrod66's Avatar
mustang tank vent questions
I have installed a 64-67 mustang tank in my 66 .i am to the point where I'm ready to mount my cap , I am thinking of using a late model cap mounted under a trap door in the middle of my bed. then taping into the fill neck mounting a vent tube to run up in to the bed side so I don't loose fuel from it sloshing up and out of the cap. I am just wondering if anyone has already done this or has any other ideas as to how to handle this situation.Name:  IMG_20150709_175824_hdr.jpg
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 07-09-2015, 07:38 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: mustang tank vent questions
You could run it up into the bedside and make a loop of steel line so water will not get in. As long as it is as high above the tank as possible I think it will be good. How did the mustang tank fit?
Jurassic-1 is offline   Reply With Quote
Old 07-09-2015, 07:46 PM   #3
hotrod66
hotrod66's Avatar
Like carp will not be doing it again. you have to move rear cross member back and remove a small brace and narrow the rails then I boxed the frame. But hey it's done so the only thing I can do is move forward.
Old 07-09-2015, 07:54 PM   #4
hotrod66
hotrod66's Avatar
