Old 07-09-2015, 10:19 PM   #1
Blogan46
Wiper motor
Hello, removing wiper motor on a 66. I removed the 3 bolts that mounts the motor to the firewall. I'm guessing there is something else I have to undo under the cowel? How do I go about that? Thank you
Blogan46 is offline   Reply With Quote
Old 07-09-2015, 10:35 PM   #2
pimpston65
pimpston65's Avatar
Re: Wiper motor
the wiper arms and linkage need to be removed
pimpston65 is offline   Reply With Quote
Old 07-09-2015, 11:03 PM   #3
Lugnutz65
Lugnutz65's Avatar
Re: Wiper motor
Yes, remove the cowl vent panel between the hood and windshield. There are about 7 little screws. Don't lose them!
Take pictures of the wiper linkage arms and how they are positioned so it's easier to put back later.
There is a nut holding the wiper linkage arms onto the motor armature and another nut holding the armature to the wiper motor. You don't have the remove both nuts, just one and then carefully remove the wiper linkages from the motor.
The wiper motor should pull out from under the dash now. Take note that there is a rubberized seal that goes between the wiper motor and the cowl. Vendors sell new ones for about $4.50 but try to save it from being damaged. It might be old and brittle and need replacing anyway.
I just went through an installation of my 1965 wiper system 2 nights ago.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-10-2015, 08:31 AM   #4
HappyHooligan
HappyHooligan's Avatar
Re: Wiper motor
Ive been working on my 60 Motor with the help of member 1963c-10 was able to find all seals.
These might help you out.
3 Mount Grommets http://www.ebay.com/itm/64-88-All-GM...mtr&rmvSB=true
Firewall Seal http://www.ebay.com/itm/1963-1964-19...mtr&rmvSB=true
Shaft Seal, under cowl below linkage http://www.ebay.com/itm/Full-Size-Ch...mtr&rmvSB=true
Hooligan
The Green Hornet
1960 Apache 10 Long Fleet - Driver and Work In Progress
The Death Star
2006 Vstar 1100 - Chopped, Bobbed, Riding the Dark Side
HappyHooligan is offline   Reply With Quote
Old 07-10-2015, 08:38 AM   #5
1963c-10
1963c-10's Avatar
Re: Wiper motor
Also....most of the cowl screws I come across are in rough shape. I install new stainless ones from home depot....runs around $1.50 and well worth the investment.
If the linkage gets out of timing....just reset using the timing marks that I showed pics of a few weeks back.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
