Old 07-09-2015, 10:23 PM   #1
Danny Bost
Danny Bost's Avatar
6.0 swap advice
OK, so I was directed here for advice. I was given a good running 6.0 out of a 2004 2500 along with a 4L80E that needs to be rebuilt. I am debating whether I want to put it in my 71 or not. If I do, I know I will need a computer since I didn't get one with it. I did get the wiring harness and the DBW pedals. Where is the best place to get the computer (I am on a tight budget). Also, I want to go with a manual, what one is best. I was told probably a NV4500. Any advice would be appreciated.
Thanks Danny
Danny
71 SWB
Danny Bost is offline   Reply With Quote
Old 07-09-2015, 10:57 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 6.0 swap advice
I'm not sure about the ecm,, maybe ebay or lqk,, on the harness my advise would be just get a custom harness built for your application,, it will make life easier and you wont regret it,, get it long enough to mount ecm under or behind the seat,, on the nv4500 that's a good choice but I can tell you from personal experience that will not be a cheap option. You can tie up a grand just connecting the engine to the nv4500. Not to mention the extreme cost of a nv4500..The 4L80 will be cheaper. I've got the 6.0 / nv4500 combo in mine.
Old 07-10-2015, 03:20 PM   #3
Angryman117
Re: 6.0 swap advice
For a computer I would check Craigslist and local salvage yards. They are getting easier to find. Did you also get the tac module with the pedals? If you are running DBW then a computer (LS1B) with the green and blue connectors is used. I am running an NV4500 with my 5.3 on my 89 Chevy. The flex plate and clutch that I needed for the swap only costs a couple hundred if that. For the wire harness I re-worked the stock one, and removed the wires for the automatic transmission, rear 02 sensors and what ever else was not needed.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
Old 07-10-2015, 05:48 PM   #4
mongocanfly
Post Whore
Re: 6.0 swap advice
I got my flywheel/clutch/bellhousing, bellcrank pivot stabilizer and trans nose for throwout bearing made by advance adapters(around $800-$1000) there are other ways to do it but they were the only ones i could find that make the whole setup..something else to consider is if you use a mechanical clutch is finding manifolds or headers that will clear the clutch linkage and cross member,, also if you keep the stock speedometer and use the gm nv4500 you will need something like dakota digital ($275-$300) to convert the electronic pulse to a mechanical drive,, if you use the dodge nv4500 it has a mechanical speedometer drive but you will have to change the input shaft to the gm one. Any way you go about it is not cheap.
Old 07-10-2015, 07:07 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.0 swap advice
$1k for the adapter parts is crazy. I mean, not that it isn't worth it if thats the setup you need...but DAMN that adds a chunk to the cost of doing business.
...its one of those days I'm glad I'm a 2wd/auto
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-10-2015, 09:45 PM   #6
mongocanfly
Post Whore
Re: 6.0 swap advice
I agree that's a lot but when a flywheel for a LS, clutch and pressure plate cost more than 600 add a couple hundred more for bellhousing,, add shipping and before you know it your there.. they just not laying around in junkyards...this started out as a build for another guy and half way thru he was tapping out on this so I bought it for a little more than what he owed. I don't think he understood me when I told him it wasn't gonna be cheap or easy..you want expensive buy a new southbend flywheel clutch and p-plate for a dodge cummings...talk about sticker shock..
Old 07-10-2015, 11:29 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.0 swap advice
I can imagine, but you might have better luck finding Cummins parts....that G gets ya everytime
Old 07-11-2015, 09:33 PM   #8
solidaxel
solidaxel's Avatar
Re: 6.0 swap advice
Are all LS flywheels the same?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-11-2015, 10:10 PM   #9
crazy longhorn
Fabricate till you "puke"
Re: 6.0 swap advice
You opened a good "fruit for thought "deal"....as I know, all of the trucks take the same "thick' flywheel (.400 thicker than the ls-1), stick shift? If I missed anything, one of the rest , will come in , & straighten it out.....no issues Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-11-2015, 10:44 PM   #10
mongocanfly
Post Whore
Re: 6.0 swap advice
I know the advance adapter site states that the iron head 6.0 and the 4.8 flywheels will not work on the gen3 ls engine..they show all gen3 ls engine will carry the same flywheel.
Old 07-11-2015, 11:46 PM   #11
solidaxel
solidaxel's Avatar
Re: 6.0 swap advice
Is there a way to I D a 4.8/iron head 6,0 and the gen 3?
Maybe by weight.
I guess I could look up part numbers from GM, thought someone might have a quick answer
LS 3 4L70E
Old 07-12-2015, 12:47 AM   #12
mongocanfly
Post Whore
Re: 6.0 swap advice
When I was looking all I could come up with was the 4.8 and 6.0 flywheel number was 12561756 and a 5.3 was 12561681..but I couldn't find a flywheel anywhere close to where I live..
Old 07-12-2015, 01:10 AM   #13
whitels1
whitels1's Avatar
Re: 6.0 swap advice
NFW1050 flywheel with an LS7 pilot bearing should get you going, do some research this is always a good place to start http://ls1tech.com/forums/conversion...swap-faqs.html followed by all of the build threads here in the LSX section.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 07-12-2015, 01:34 AM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.0 swap advice
Maybe by weight.
When you look at the heads...they aren't aluminum....
GenIII' could have iron heads for the first year or two. 99/2k trucks could have iron heads, at least on the 6.0's. After that, they pretty much went all to aluminum heads. All joking aside, if it has iron heads, its usually worth walking away from.
A 4.8/5.3 will look the same, but the 6.0's will have a "6.0" stamping on them.
Old 07-12-2015, 09:12 AM   #15
solidaxel
solidaxel's Avatar
Re: 6.0 swap advice
Br3w, not the engine weight, the weight of the "FLYWHEEL", are there different weights or are they all the same for the LS?
LS 3 4L70E
Old 07-13-2015, 12:37 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.0 swap advice
At least from what I've seen, they sure as hell seem the same to me. Unless there is something special on manuals that I havent seen, all the auto trucks have had the same flywheel, just with or without the spacer.
Old 07-13-2015, 01:32 PM   #17
mongocanfly
Post Whore
Re: 6.0 swap advice
Got this off novaks..dont know if it helps or not...The 5.3L Vortec has never been available with a manual transmission option. Only the 4.8L and 6.0L Vortecs featured manual transmission options and therefore a factory flywheels neutral balance*does match the 5.3L and other Gen. III+ engines
Old 07-14-2015, 11:46 AM   #18
solidaxel
solidaxel's Avatar
Re: 6.0 swap advice
Thanks folks, weight is the same and the bolts (location) are the same is the diameter and tooth count the same as the old Chevy flywheels?
I guess I need to find one and but it side by side and weight it
LS 3 4L70E
Old 07-16-2015, 10:36 PM   #19
Danny Bost
Danny Bost's Avatar
Re: 6.0 swap advice
Thanks for all of the great input. I may just go with the 4L80E due to the cost of the manual. It is going to take me a while to assemble everything I need anyway.
Danny
Danny
71 SWB
Old 07-17-2015, 09:36 AM   #20
solidaxel
solidaxel's Avatar
Re: 6.0 swap advice
Danny, thanks for prompting me to ask some questions on your thread
I did not mean to hijack your thread
LS 3 4L70E
