Old 07-10-2015, 12:05 AM   #1
Dentguy
Dentguy's Avatar
Front serpentine pulley configuration
Picked up a built LQ4 with L92 heads and intake and am compiling parts to swap into my 67.
What's the preferred pulley configuration and water pump so all align correctly?
Or is there a single source to do all of pulleys and install swap parts? Including mounts, headers, serpentine system, power steering, etc....I'm not against spending money as long as the parts are correct.
Thanks guys!
Dentguy is offline   Reply With Quote
Old 07-10-2015, 12:15 PM   #2
bpatrol
Re: Front serpentine pulley configuration
personally for me I would do a f body setup with a f body water pump.
if not run a truck setup with a 2010 l99 Camaro water pump. new Camaros have the same spacing as a truck
good luck with whatever you chose
bpatrol
bpatrol is offline   Reply With Quote
Old 07-25-2015, 06:30 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
I have an 05 LQ9 swap and I want to keep the stock parts, jest need to eliminate the factory AC pump. Is there a idler pulley replacement and a shorter belt? I thought I was that option somewhere but cant find any info on it.....
Rich
1972 K5 Blazer CST Click HERE
Old 07-25-2015, 07:05 PM   #4
dayj1
The AC compressor has its own belt. Just remove the compressor, bracket, and belt. No additional parts are needed.
dayj1 is offline   Reply With Quote
