Old 07-10-2015, 11:23 AM   #1
DRGunn
Stubborn oil filter
Just did the first oil change on the 71. The oil filter did not want to budge. I destroyed my belt type filter wrench and almost folded the filter in half doing it.
After applying (long) screwdriver and hammer, and peeling some of the case back) it started to yield. Pics to follow (as soon as I figure out how).
What causes the filter to "stick" to the engine?
DRGunn is offline   Reply With Quote
Old 07-10-2015, 11:28 AM   #2
GRX
GRX's Avatar
Re: Stubborn oil filter
Been there, done that. What causes the filter to "stick" to the engine? Two things usually. Dry application and over tightening.
And to the Forum
GRX is offline   Reply With Quote
Old 07-10-2015, 11:32 AM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
What GRX said... and also (not sure if this is from a recent rebuild) if you painted the sealing surface on the block.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-10-2015, 11:45 AM   #4
n33k0
I've had that happen a few times on different vehicles. If it doesn't budge after a few minutes of turning by hand, it gets the clamps! (squeeze & turn the filter with big clamps)
n33k0 is offline   Reply With Quote
Old 07-10-2015, 12:12 PM   #5
Lemield
Lemield's Avatar
Hey DRGunn,
Since you are a neighbor, come over and borrow my '460's'.....Never met a filter they couldn't take off....
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 07-10-2015, 12:23 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
What they said. The filter will tighten itself (don't ask me why, but they always do) so when you install it, after wiping the engine mounting surface clean and lightly oiling the filter gasket, just snug the new filter by hand only.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-10-2015, 12:40 PM   #7
DRGunn
I have several pairs but the filter is tucked away in what appears to be difficult at best to get to the filter.
But the ball peen and (long) screwdriver succeeded in freeing it up.
I'm up by Standley lake (N. side). Just obtained this truck.
Old 07-10-2015, 12:41 PM   #8
Sklptrljay
Sklptrljay's Avatar
Originally Posted by lemield View Post
hey drgunn,
since you are a neighbor, come over and borrow my '460's'.....never met a filter they couldn't take off....
x2
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 07-10-2015, 03:35 PM   #9
Lemield
Lemield's Avatar
I'm about 64th and Sheridan. Got any pictures of the truck to show all of us?
Larry
Old 07-10-2015, 04:17 PM   #10
DRGunn
A little rough but still has the push button radio...
Old 07-10-2015, 04:19 PM   #11
Lemield
Lemield's Avatar
She looks good to me.
Larry
Old 07-10-2015, 09:04 PM   #12
truckster
truckster's Avatar
Jiffy Lube, WalMart Auto Service, any quick-change oil place. Most filter manufacturers recommend lubing the gasket with fresh oil and then spinning it on and tightening it 1/4 turn after the gasket contacts the mounting surface. The guys who work at those places tend to crank the filters down tight because they think they'll leak if they don't.
truckster is offline   Reply With Quote
Old 07-10-2015, 09:25 PM   #13
jabborabbo
jabborabbo's Avatar
I've had the same problem on my '67 a couple of times...put fresh oil on the new filter gasket, tightened it 1/4 turn by hand after it made contact with the block, and then destroyed it a few months later trying to get it off...
jabborabbo is offline   Reply With Quote
Old 07-11-2015, 11:48 AM   #14
WIDESIDE72
WIDESIDE72's Avatar
A few years back I helped a buddy swap a Ram jet 350 into his 68 stepside. It came from gm with filter installed. He ran it through the break in procedure as they specified, but when he went to change the oil he couldn't get the filter off. We tried the old screwdriver through the side trick. We got all of the canister shredded but it still wouldn't budge. He ended up with nothing but the steel ring left and had to use a chisel to get that off. He called gm and they said "oh, we've had a few people call and tell us the same thing." Gee thanks. Nothing like spending a day beating on a filter, risking shredding your hands on razor sharp metal, only to be told, basically, "yea, we know, but decided not to tell anyone or do anything but keep selling them as is.l
WIDESIDE72 is offline   Reply With Quote
Old 07-11-2015, 01:42 PM   #15
GRX
GRX's Avatar
Rather a fan of the socket type tool, provided there is space.
Old 07-11-2015, 03:01 PM   #16
72chevyk10
I built it
72chevyk10's Avatar
on my big block i had the trans mount bolts go through the oil filter mount and locked it in. after shredding the filter we found the bolt holding it on.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 07-11-2015, 06:55 PM   #17
WIDESIDE72
WIDESIDE72's Avatar
You lost me there...
Old 07-11-2015, 07:05 PM   #18
treveiger
treveiger's Avatar
That looked like my filter on my Honda last time I changed it. Those things welded on there!
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 07-12-2015, 12:04 AM   #19
72chevyk10
I built it
72chevyk10's Avatar
big blocks have a trans bolt that goes through the oil filter mount. too long a bolt will lock the filter down
Old 07-13-2015, 12:55 PM   #20
WIDESIDE72
WIDESIDE72's Avatar
Huh... Thats a new one on me. Ive had more sbc than i can count, but only recently acquired a 454 for my 79 malibu. I also have a 70 Longhorn with a big block 400. My dad had an 80 GMC c30 that had a 350 when he bought it. We swapped it for a 72 454. Never had an issue, but then again we never did any trans swaps after that.
Old 07-14-2015, 04:38 PM   #21
72chevyk10
I built it
72chevyk10's Avatar
my truck is kinda a mickey mouse rig. so it probly got longer trans bolts somewhere along the way haha. put a little bit shorter bolt at oil filter and never had another issue
