New cam?
Im currently running lunati vodoo cam in a 355 with vortec heads, flattop pistons. Current cam specs are.
Basic Operating RPM Range: 1,000-5,500 Intake Duration at 050 inch Lift: 213 Exhaust Duration at 050 inch Lift: 219 Duration at 050 inch Lift: 213 int./219 exh. Advertised Intake Duration: 256 Advertised Exhaust Duration: 262 Advertised Duration: 256 int./262 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.454 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.468 in. Valve Lift with Factory Rocker Arm Ratio: 0.454 int./0.468 exh. Lobe Separation (degrees): 112 Im wanting more power and my question is how much HP will i gain from switching to one of these cams. Note my heads already have new springs to support a bigger lift. Basic Operating RPM Range: 1,400-5,700 Intake Duration at 050 inch Lift: 219 Exhaust Duration at 050 inch Lift: 227 Duration at 050 inch Lift: 219 int./227 exh. Advertised Intake Duration: 262 Advertised Exhaust Duration: 268 Advertised Duration: 262 int./268 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.468 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.489 in. Valve Lift with Factory Rocker Arm Ratio: 0.468 int./0.489 exh. or this cam Basic Operating RPM Range: 1,800-6,000 Intake Duration at 050 inch Lift: 230 Exhaust Duration at 050 inch Lift: 236 Duration at 050 inch Lift: 230 int./236 exh. Advertised Intake Duration: 274 Advertised Exhaust Duration: 286 Advertised Duration: 274 int./286 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.490 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.490 in. Valve Lift with Factory Rocker Arm Ratio: 0.490 int./0.490 exh. Lobe Separation (degrees): 110 or this Basic Operating RPM Range: 1,800-6,200 Intake Duration at 050 inch Lift: 227 Exhaust Duration at 050 inch Lift: 233 Duration at 050 inch Lift: 227 int./233 exh. Advertised Intake Duration: 268 Advertised Exhaust Duration: 276 Advertised Duration: 268 int./276 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.489 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.504 in. Valve Lift with Factory Rocker Arm Ratio: 0.489 int./0.504 exh. Lobe Separation (degrees): 110 |
| Bookmarks |
