Old 07-10-2015, 05:48 PM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Fan shroud question.
With the onset of some really hot weather, I would like to add a fan shroud. My 350/260 crate with GM serpentine system runs right at the thermostat range (180) while moving. I have a new copper/brass radiator and it works really well. It can idle in 95*+ weather thru a typical drive-thru line, but the temp rises to 220*. Not a problem, but it appears that a shroud would help. Here's the the rub - The serpentine fan is 20" in diameter, way too big for my factory shroud. The fan sits almost dead center in the radiator (about 2-1/2" back from the core.)........... Have any of you guys, running the serpentine set-up, found any shroud that fits?
I don't have access to the fab. shop I used to, so any help would be appreciated.
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
TobyArnot is offline   Reply With Quote
Old 07-10-2015, 07:19 PM   #2
RustyBucket
RustyBucket's Avatar
Re: Fan shroud question.
Speedway sells a few kits that might work. Not much money and maybe could be tailored to work/look good.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 07-11-2015, 08:29 PM   #3
chiefcfd
chiefcfd's Avatar
I changed my fan blade to an 18 inch fan. Fits the stock shroud.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 07-11-2015, 08:45 PM   #4
leftybass209
leftybass209's Avatar
Have you tried looking for a different sized fan? That seems a much cheaper solution as opposed to picking up a diy shroud kit that needs custom mounts.
leftybass209 is offline   Reply With Quote
Old 07-11-2015, 11:09 PM   #5
TobyArnot
TobyArnot's Avatar
DUH! My brain never even thought about that.
Any part numbers for an 18" reverse-rotation fan?
MY MOTTO:
Old 07-12-2015, 10:04 AM   #6
chiefcfd
chiefcfd's Avatar
I went with the Derale. Part #D17918. I think there were a couple different options.
https://www.etrailer.com/Radiator-Fa...le/D17918.html
