Old 07-10-2015, 10:29 PM   #1
flood1964
65 wheels
I need advice on a wheel size for disc brake conversion. My stock wheels won't clear the calipers. i'd like to do a stock size wheel and tire on the front and go with the widest rear tire possible. By the way... it has a 4/6 drop.
flood1964 is offline   Reply With Quote
Old 07-11-2015, 12:02 PM   #2
jayoldschool
Moderator
Re: 65 wheels
Use the later early 70s six lug wheels that clear discs.
jayoldschool is offline   Reply With Quote
Old 07-11-2015, 01:52 PM   #3
yote1234
yote1234's Avatar
Re: 65 wheels
I had the same problem.. gotta find 4 nub wheels. the nubs that hold the hubcap on. 3 nub wont work..
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 07-13-2015, 06:23 PM   #4
flood1964
Re: 65 wheels
I'm open to putting a different style wheel on my truck. I'm thinking a 15x8 six lug will work. Does anyone know if this size wheel will fit on a 1965 c10 with disc brake conversion and 4/6 drop and does anyone have a set for sale?
Old 07-13-2015, 06:48 PM   #5
jayoldschool
Moderator
Re: 65 wheels
Yes, the 4x4 15x8 rally wheels with rectangular holes will work.
Old 07-13-2015, 06:54 PM   #6
flood1964
Re: 65 wheels
Are there any other kind of caps that can be used on that rim?
Old 07-13-2015, 07:46 PM   #7
AcampoDave
AcampoDave's Avatar
Re: 65 wheels
So you converted to disc and stayed 6 lug? I suppose you know that 5 lug offers a lot more options.
AcampoDave is offline   Reply With Quote
Old 07-13-2015, 08:11 PM   #8
flood1964
Re: 65 wheels
Yes sir... the reason I stayed with six lug was because i wanted to keep the front the same as the back.
Old 07-13-2015, 09:34 PM   #9
dougf
dougf's Avatar
Re: 65 wheels
Just keep your eyes open for some 4-nub steeliies. I'm in the same boat.
dougf is offline   Reply With Quote
Old 07-13-2015, 09:44 PM   #10
flood1964
Re: 65 wheels
What are the exact size Steelies I should be looking for?
Old 07-13-2015, 10:09 PM   #11
dougf
dougf's Avatar
Re: 65 wheels
This thread says it better than I could: http://67-72chevytrucks.com/vboard/s...d.php?t=560599
Good luck!
Old 07-13-2015, 10:14 PM   #12
corvettejim1968
corvettejim1968's Avatar
Re: 65 wheels
here is mine
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
