Dually wheel tubs
I've never removed the tubs from a bed once I remove the filler strip that's on inside dose that open it up to gain access to to the nuts on the studs that hold on the tubs on to the bed side
I have no time for this
Re: Dually wheel tubs
Yes it will give you access to the nuts on the back side of the tubs but you will probably end up spinning the studs out of the tubs. I got the tubs off and then spent a lot of time spinning the nuts off with vice grips holding the studs. Then I used Speed Grip and spun them back into the tubs afte I got done bodyworking and priming the tubs.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
Thanks the old bed I took off was something that was put together from aftermarket parts they drill holes on the in side of the bed to tighten the tub bolts the bed was junk there was more bondo then fiberglass on the tubs this bed is in great shape it only has a few small dents a surfs rust I taking the bed to get blasted the only thing is the hole for gooseneck hitch looks to far forward so might have weld it up and move it back
Do all the bed have these metal brackets I don't remember seen them on other beds I looked at
I have never seen those metal tabs befor. Those tubs are also glued on as well.
Yes it looks like it has a bead of seam seal around them
![]() Join Date: Apr 2009
Do they have the metal tabs on the top 4 or so bolts and thanks for the help and info
Here's what it looks like in the service manual (1985 model year).
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thanks that help I just don't want to brake nothing if I can keep from it so I can reinstall after painting with out trying to track done parts that got broke
