Old 07-11-2015, 03:40 PM   #1
LT102
LT102's Avatar
Removal of rubber from burnout - suggestions
What have you used to clean off the rubber residue left after a burnout. Most people think they look cool but I actually try to avoid burnouts as they cause such a mess with the rubber residue. Did a test launch earlier today after doing some transmission work. Tires had good bite at first then broke loose and then up in rubber smoke. Now it's cleanup time.
LT102 is offline   Reply With Quote
Old 07-11-2015, 04:38 PM   #2
ole dollor
ole dollor's Avatar
Re: Removal of rubber from burnout - suggestions
if you have a little time , mother nature will remove them for you .....looks like your trany is working good .
ole dollor is offline   Reply With Quote
Old 07-11-2015, 04:45 PM   #3
RustyBucket
RustyBucket's Avatar
WD40 or mineral spirits work pretty good
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 07-11-2015, 05:27 PM   #4
hugger6933
Next time your gonna do that wax the bottom lower half of the bed and leave it on then when your done playing just wipe the rubber and wax off at one easy step. I used to do that on my racecar. other than that just rub it down with your hand and it should fall right off.
hugger6933 is offline   Reply With Quote
Old 07-11-2015, 11:22 PM   #5
snipescastle2
snipescastle2's Avatar
Talking Re: Removal of rubber from burnout - suggestions
Some people rub some vasoline on that area behind the rear tires,makes it come off pretty easy.
snipescastle2 is offline   Reply With Quote
Old 07-12-2015, 06:22 AM   #6
Tony
Just add some numbers on the windows and people will think you're coming from the track...
Tony is offline   Reply With Quote
Old 07-12-2015, 10:22 AM   #7
CST10
CST10's Avatar
Pledge sprayed on before the burn out will have it where you can just spray with a water hose to get it all off.
That's what I use on my camaro at the race track.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 07-12-2015, 04:47 PM   #8
DillonGMC
DillonGMC's Avatar
Goo gone works pretty good.
The Pontiac V8: the original Super Duty.
DillonGMC is offline   Reply With Quote
Old 07-12-2015, 06:22 PM   #9
LT102
LT102's Avatar
Went back to the scene of the accidental burnout and was not happy to see there was only one tire mark. My truck has a posi!!! I seem to go from one mechanical problem to another. Thanks for all the suggestions thou.
Old 07-13-2015, 04:10 PM   #10
cooperhw
cooperhw's Avatar
Good news is you only have to clean rubber off of the wheelwell on one side of the truck.
I used to use Pam. Spray it on liberally before burnouts. Comes off easy later on.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-13-2015, 07:49 PM   #11
LT102
LT102's Avatar
Sorry for any confusion, I meant the rubber on the truck not the roadway.
Old 07-13-2015, 08:22 PM   #12
Chris92
Chris92's Avatar
WD40 as posted above will melt it away. Easiest and fastest way.
Chris
Build Thread for CSautosports 69 SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=675701
Chris92 is offline   Reply With Quote
Old 07-13-2015, 09:23 PM   #13
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
"WD40, duct tape and bailing wire". Until recently, never found much use for bailing wire......Works great to tap into screw holes that are stripped. Add velcro to the list. If something light needs to be mounted and can't be bolted down..............velcro. I use it for lots of stuff (e.g. finish piece of hickory face for front/bottom dishwasher). Have an interesting "invention" using the stuff. Works great. I'm not interested in paying for a patent. Not sure it's worth the effort either. It's real simple and cheap too. Addresses a common household inconvenience, for which there are no current purchase options.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
