07-11-2015, 10:20 PM | #1 |
New Roadster Shop Chassis FYI
07-12-2015, 08:51 AM | #2 |
Re: New Roadster Shop Chassis FYI
Very nice.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-15-2015, 04:14 PM | #3 |
///Relaxed Atmosphere
Here a few pic's of it that I took while in Columbus last weekend. really nice chassis
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
07-21-2016, 03:25 PM | #4 |
07-21-2016, 05:03 PM | #5 | |
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-22-2016, 02:49 AM | #6 |
Is it wrong to drool a lil over that frame lol.The price on it isn't that bad vs all you get out of it.
08-01-2016, 11:30 AM | #7 | |
01-31-2017, 05:17 PM | #8 |
I've been dying to see someone do a complete build with one of these. I have so many questions.
-It says will lay rocker on a 29" tall tire. I assume that legit means rocker rather than pinch. But does that mean 29" tall in the rear? If going 24's that would be a really small wheel width. They say can support 12" wides, but in a 24" wheel that would be 30+" tire. Also how deep can the dish be on a 12' wide wheel? -How much cutting is needed? Assume tunneling the cab a bit for 1 piece drive shaft? Fire wall for 24's?, high hump, core support trim?, obviously bed mods. I have seen a couple guys out there building in shops, but no one releasing specs on wheel size or the amount of cutting to other areas. |
02-01-2017, 05:43 AM | #9 |
Starting at 9,900.00 eeck..
02-01-2017, 09:34 AM | #10 |
I'm sure its worth the price considering, most of us modify front cross member and the rear cross member. if you add the fact that its a stronger chassis with a better breaking system, its really a no brainer, if you have the pesos.
