Old 07-12-2015, 01:11 AM   #1
crazychevyc10
How do you have your airbag valves setup?
Hey guys I'm trying to get some ideas on where and how to mount my valves for my airbags. Anyone have pictures of their airbag setup?
Thanks!
crazychevyc10 is offline   Reply With Quote
Old 07-13-2015, 02:51 PM   #2
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Re: How do you have your airbag valves setup?
What kind of valves do you have?
I have the RideTech manifold block bolted to my frame rail. Super Easy. If you have the individual brass valves its gonna look like you robbed a hardware store. Nothing you can do about that, I had SMC's on another truck. Now I'm older, and like reliability so I have some manual valves for another truck. Work everytime, battery or not.
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 07-13-2015, 02:57 PM   #3
shawley
I did mine under the bed in between the frame, Went with an Accuair E-Level
Looks a little busy here, but it's all accessible, from below, and same with the fuses and everything,
shawley is offline   Reply With Quote
Old 07-13-2015, 05:24 PM   #4
tsetsaf
My valves are located inside the frame rails near all four corners. If I did it over again I would use a centralized manifold with hard lines running to the bags. Ours is a daily driver, now 26,000 miles in 2 years, and I have run into line failures on the road.
Last time was a year ago in the middle of nowhere Utah; the exhaust heated the frame and melted the nylon line that was touching the frame 4 inches away. It was pissing about 5 psi a minute so we nursed the truck back home with my wife manually adding air using the controller and then stopping every 10 minutes to let the compressor catch back up.
Another note. Only buy the best valves, fittings and lines; and then carry at least one spare of everything with you.
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
