Radeator to low
Will my radeator being this low put it at risk of being damaged by rode debree? Do you think I should raise it to it's stock location?
Moderator
![]() ![]() Join Date: Aug 2011
Re: Radeator to low
Show how you lowered it. I was thinking of doing the same thing to mine.
![]() Maybe even making a larger custom radiator.
Re: Radeator to low
That is how the aftermarket radeator mounted. I think the holes are in the wrong spot on the side brackets. It is a 62 so the height of the radeator is determined by where the holes are drilled on the side mounts.
Re: Radeator to low
should not be a problem at all just make sure you run a fan shroud to get proper cooling and what radiator is that ? brand and model number ?
![]() Join Date: Mar 2005
Re: Radeator to low
You'll be ok. Just remember that you'll have the lower portion of the header panel covering the lower tank and you'll have a bumper in front of that.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Post Whore
![]() Join Date: Mar 2013
Re: Radeator to low
You can make a skid panel to cover that. But it should be fine.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Re: Radeator to low
It is a US Radiator I don't have the model# but if you go on there websight it is the 60-62 c10 double row aluminum radiator with the built in trans cooler.
Re: Radeator to low
Chevy addict
Re: Radeator to low
Shouldn't be a problem as some HD radiators mount to the lower portion of the front cross member.
